02 impala wire diagram
loudnlow
Member - Posts: 13
Posted: January 04, 2003 at 8:26 AM / IP Logged
   Does anyone have a wire diagram for the 02 cheverolet impala?  I am just doing keyless entry on it, not the full alarm or remote start.  Please let me know and thanx for any info!!
Chris Luongo
Platinum - Posts: 3,746
Posted: January 04, 2003 at 1:14 PM / IP Logged
The Impala is a popular car, and seems to come up around here quite often.  Do a search and you'll find what you need.
secureauto
Copper - Posts: 197
Posted: January 05, 2003 at 6:20 PM / IP Logged
The info I have is for 00-01, I'm sure they're the same, but double check them anyway.
12 Volt (+)
16ga. Orange at R.K.E. above and left of steering column in Large Gray connector (connectors face forward)
Ignition 1
18ga. Pink at same
Ignition 2
12ga. Pink at ignition harness
Ignition 3
12ga. Green at same
Accessory 1
18ga. Black at R.K.E. in Large Gray connector (
Accessory 2
12ga. Orange at same
Starter
12ga. Yellow at back of fuse box (can be seen from under dash looking back up into fuse box)
Horn
18ga. Black (-) at R.K.E. in Pink connector
Tachometer
18ga. Violet/White at top of engine under plastic cover
Lights (+)
18ga. BROWN / White at light switch
Lights (-)
18ga. Blue at R.K.E. in Small Gray connector
Brake Lights
18ga. White (+) at brake pedal switch
Door 1
18ga. Blue (-) (driver’s door only) at R.K.E. in Small Gray connector
Door 2
18ga. Blue/White (-) (passenger doors) at same
Door 3
Door 4
Interior Lights
18ga. Blue/White (-) at same in Pink connector
Trunk/Hatch
18ga. RED / Black (-) at same in Large Gray connector
Hood Pin
Trunk Release
18ga. Black (-) at same in Small Gray connector, motor wire is 18ga. Lt. Blue (+) in Large Gray connector
Lock (switch)
18ga. ORANGE / Black (-) @ 500 - 1000 ohms at same
Unlock (switch)
Same wire @ (-)
Driver Unlock
Arm (key)
Disarm (key)
18ga. Lt. Green (-) at same in Small Gray connector (extended pulse also unlocks doors)
Arm Input
14ga. Gray (M) at R.K.E. (connect alarm’s inputs to ground through a 10k ohm resistor)
Disarm Input 1
14ga. Tan (M) at same (connect alarm’s inputs to ground through a 10k ohm resistor)
Disarm Input 2
14ga. Tan (M) at R.K.E. or at passenger’s door harness (connect alarm’s inputs to ground through a 10k ohm resistor)
LF Window Up
LR Window Up:
