installing crime guard 850i3 in a 89 crx
zinktphilly
Member - Posts: 6
Posted: April 14, 2006 at 7:26 PM / IP Logged
can anyone help me with the alarm pinout i have diagrm of car wiring need alarm diagram
infinkc
Copper - Posts: 438
Posted: April 15, 2006 at 8:13 PM / IP Logged
12volts WHITE/ black    +   ign harness, f/b plug
Starter BLACK/ white    +   ign harness, f/b plug
Second Starter
Ignition BLACK / YELLOW    +   ign harness, f/b plug
Second Ignition
Third Ignition
Accessory yellow    +   ign harness, f/b plug
Second Accessory blue/white    +   ign harness, f/b plug
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+ RED / green      switch harness, f/box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger GREEN/ red    -   either running brd
Notes: Harness running down and forward from dash indicator has door and hatch triggers.
Dome Supervision
Trunk/Hatch Pin GREEN/ black    -   at light or indctr
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue    ac 2-pin at dist, tach
Notes: Pin A11 behind gauges
Wait to start
Brake Wire GREEN / WHITE    +   brake pedal switch
Parking Brake
Horn Trigger blue/red    -   steering column
There are 10 types of people in the world, ones that understand binary and ones that dont.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
