viper 719XV not learning tach
surendrant
Member - Posts: 34
Posted: April 16, 2006 at 9:48 PM / IP Logged
i installed a viper 719XV in a 1999 toyota camry. everything works fine except for that fact that the dam thing wont learn the tach. I checked the wire and its giving me .3 - .5 AC volts. And its the rite wire according to directechs. Any input would be greatly appreciated. Thanks.
swamprat323
Gold - Posts: 1,335
Posted: April 16, 2006 at 9:55 PM / IP Logged
make sure the 791 is is program for tach, aslo you only have about 10 seconds to start car and press and hold valet. also double check your connestions
MrSuperStar
Member - Posts: 33
that voltage seems too low, that wire are you using exactly, is this the 4 or 6 cylinder?
surendrant
Member - Posts: 34
Posted: April 16, 2006 at 9:58 PM / IP Logged
well i know that the unit comes with tach sensing as default. Its a 4 cyinder 99 camry.
Ravendarat
Platinum - Posts: 2,806
Posted: April 16, 2006 at 11:23 PM / IP Logged
ok, and what wire did you hook up to.
kaezoo
Copper - Posts: 125
Posted: April 17, 2006 at 8:09 AM / IP Logged
Are you able to get into the programming mode at all? If the heavy pink wire from the relay pack isn't connected to ignition, or if the ribbon cable is loose or disconnected at either end, the unit won't learn tach because it can't detect you've turned the key.
