Subaru SVX Tack wire Location
trieck1232
Member - Posts: 29
Posted: May 08, 2006 at 6:23 PM / IP Logged
Where exactly is the wire it is supposed to be yellow, off the ecm, which is above the brake pedals, if im correct...I can't find the wire at all the car is a 1995 Subaru SVX Code alarm 425/545 combo everything else works fine, OR mabie i can use the alarm in tachless mode, but im not sure how to get it into this mode all the manual talks about is learning the tach which it wont do, because the tach wire isnt hooked up.
thanks,
travis
---Travs---
mo12v
Posted: May 08, 2006 at 6:41 PM / IP Logged
Yellow wire is in a 16 pin plug, ....pin 16@ ECM.
MO
