02 nissan x-terra does not rs when cold
alariskirein
Member - Posts: 15
Posted: May 09, 2006 at 1:41 AM / IP Logged
i have a problem ,hope somebody can help. i install an prestige aps 996a rs on a 02 nissan x-terra and everything works but the remote start, when i tryed to rs the starter just keeps cranking but do not engage. i have this problem before with an 95 nissan sentra ,when the car get hot the rs works.by the way the 02 x-terra doesn't seem to have a transponder on the key.does anyone have the window roll up-down wire info i have the omega info disc but doesn't show that info. any help will be apreciated.i saw that there's a cold start wire but don't say what polarity has.
rallysport
Copper - Posts: 172
Posted: May 09, 2006 at 1:53 AM / IP Logged
cold start is GREEN/ YELLOW with + polarity
windows
LF blue - blu/blk blue
RF blu/yel - blu/wht
LR grn/red - grn/yel
RR grn/wht - grn/blk
all at drivers door switch
alariskirein
Member - Posts: 15
Posted: May 11, 2006 at 11:31 PM / IP Logged
thanx a lot .i hope it works. so how do i have to connect this wire , can i connect it with the second ignition from the alarm ?also my program shows a BLACK/ pink wire for the cold start ,and the location is on the ignition sw.is this the same wire ?  what kind of connection goes for the windows, reversal rest at ground, positive or nothing?thank you, have a good day.
92 honda accord coupe
focal  polyglass components 6.5"
mb quart premium components  6.5"
mb quart discuss components 4"
alpine cda-9855 headunit w/ 6 disc mp3 cd changer
focal polyglass sub 40v2 16"
dxdenis02
Copper - Posts: 72
Posted: May 12, 2006 at 10:21 AM / IP Logged
cold start wire is just that a starter wire  i usually wrapped them together
use a meter to verify the correct wire
use a meter to test the windows system
if you dont have or dont know how to use a meter please dont install
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
