Adding extra status LED
jonnylee
Member - Posts: 17
Posted: May 14, 2006 at 9:36 PM / IP Logged
I have installed Viper 560XV and everything is wokring fine. I am thnking of adding one extra status LED just the same as the one with bright blue with two wires, blue and red.
My question is can I just add(connect) this extra LED's blue wire to the existing blue wires and red wire to the red ? without adding resistor ?, in other word, the parallel connection.
The reason why I want to add one more LED is depending on sun shine, only one LED is not easily visible.
Thank you in advance for you help.
Twelvoltz
Platinum - Posts: 2,384
Posted: May 15, 2006 at 6:34 AM / IP Logged
When adding more than one LED I would recommend wiring them in series.
jonnylee
Member - Posts: 17
Posted: May 15, 2006 at 7:24 PM / IP Logged
Twelvoltz,
Thanks for the advise, I just want to make sure that in series connection
connet to the (+) from the brain to LED-1(+) connect to LED-1(-) to LED-2(+)
LED-2(-) connect to connct to the brain(-)
Is this right ?, I do not want to fry anything, no resistor is needed ?
Thank you again for your advise, very much appreciated
Twelvoltz
Posted: May 15, 2006 at 9:08 PM / IP Logged
That is a correctly wired series circuit, yes.
jonnylee
Member - Posts: 17
Posted: May 16, 2006 at 12:05 AM / IP Logged
Twelvoltz,
Thank you again for your prompt reply.
Very much appreciated.
