2001 Toyota Camry Alarm/Remote Start Wiring
Ohmz
Copper - Posts: 193
Posted: January 09, 2003 at 1:00 PM / IP Logged
I need a wiring diagram for this car. Thank you in advance!
Platinum - Posts: 12,488
Posted: January 09, 2003 at 1:17 PM / IP Logged
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red *1        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|dk. blue/white *3   |-  |org plug bottom of fusebox  |
|     POWER UNLOCK|dk. blue *3         |-  |org plug bottom of fusebox  |
|       LOCK MOTOR|blue/red            |   |org plug bottom of fusebox  |
|     UNLOCK MOTOR|blue                |   |org plug bottom of fusebox  |
|    DISARM DEFEAT|blue/black          |   |org plug bottom of fusebox  |
| PARKING LIGHTS +|green               |   |bottom of fusebox *4        |
| PARKING LIGHTS -|green               |   |steering column             |
|       HEADLIGHTS|RED / yellow          |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |top of fuse box *5          |
|  TRUNK/HATCH PIN|RED / yellow          |-  |light or sw. in trunk       |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blu/blk (key sense) |-  |ignition harness            |
|       TACHOMETER|black or gray *2    |   |*2                          |
|       BRAKE WIRE|GREEN / WHITE         |+  |bottom of fusebox *4        |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|green - red         |A  |drivers door switch         |
|  RF WINDOW UP/DN|grn/wht - RED / blu   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|grn/yel - RED / yel   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|grn/blk - RED / blk   |A  |drivers kick panel          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  *1 There are two BLACK/ red wires going to the same pin at the plug.  use either one.     *2 On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor.  On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the strut tower.  The module says Denso on it.  *3 The lock wires are about 18 gauge.  They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.     *4 In a white connector just below the fuses with the wires exiting out toward you.    *5 Located in a seven pin plug on the top right side of the fuse box.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
