4runner Keyless entry brain location
Ishinc
Copper - Posts: 109
Posted: June 14, 2006 at 12:44 AM / IP Logged
Does anybody have any experiences with a 2000 Toyota 4runner? I am looking for the factory keyless entry brain. I have no idea where it is and it is not under the seat for sure!
Thanks!
mo12v
Posted: June 14, 2006 at 7:44 AM / IP Logged
RKE ModuleBUILT INTO BODY ECU
ECU Located Behind Driver Dash In Fuse Block
MO
Ishinc
Copper - Posts: 109
Posted: June 14, 2006 at 10:59 AM / IP Logged
Thanks Mo12v!
Are you saying that its built into the fuse block, its not a seperate box?
mo12v
Posted: June 14, 2006 at 6:03 PM / IP Logged
Correct
MO
Ishinc
Copper - Posts: 109
Posted: June 17, 2006 at 9:56 PM / IP Logged
Thanks!
If I knew this earlier it would have save me hours of searching under the dash!
Any chance you are familar with 529T window rollups?
My problem is that my alarm arms when the keyless locks the doors (press lock on remote). I have found that wire and hooked up my window modules to it. Everything works fine but now my windows roll up even when I press the lock button inside the car!
Is there another wire I should use to trigger my window module?
Thanks!
mo12v
Posted: June 18, 2006 at 4:06 PM / IP Logged
Does your 4 Runner have Total Closure?  Does the Sunroof close with the Remote?
MO
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
