2006 ford fusion alarm wiring
jennifers
Posted: August 03, 2006 at 12:00 PM / IP Logged
I have a 2006 ford fusion and i need help finding the wiring diagram for the vehicle to hook up an alarm system. Any assistance will be greatly appreciated. Thank you
swamprat323
Gold - Posts: 1,335
Posted: August 03, 2006 at 12:18 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / FUSION / 2006 / Remote Start
12volts BROWN / red (15A)   +   ignition harness
Starter blue/white   +   ignition harness
Second Starter N/A
Ignition WHITE/ orange   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / green   +   ignition harness
Second Accessory N/A
Keysense blue/gray   +   ignition harness
Power Lock gray / YELLOW   -   driver kick or SJB, conn. C, pin 4
Notes: The SJB (Smart Junction Box) is part of the fuse/relay box under the driver side dash.
On vehicles with memory seats, the power lock/unlock wires are in the passenger kick or the SJB, and you have to press the passenger door lock switch while metering the wires.
Power Unlock PURPLE / gray   -   driver kick or SJB, conn. C, pin 10
Lock Motor gray/brown   5wi driver kick or SJB, conn. E, pin 17
Unlock Motor blue/green   5wi driver kick or SJB, conn. E, pin 27
On vehicles with memory seats, the unlock motor wire is found at the driver door module in the door.
Parking Lights+ gray / YELLOW   +   driver kick or SJB, conn. E, pin 30
Parking Lights- gray   -   switch or SJB, conn. D, pin 5
Hazards BROWN / yellow   -   switch or SJB, conn. D, pin 20
Turn Signal(L) blue/green (F), gray/brown (R) +   SJB, conn A, pin 21; conn E, pin 11
Turn Signal(R) yellow/pur (F), PURPLE / org (R) +   SJB, conn A, pin 9; conn E, pin 7
Reverse Light GREEN / WHITE   +   driver kick or SJB, conn. E, pin 21
Door Trigger use dome supervision wire
Notes: The individual door trigger wires rest at ground and go to an open circuit when the doors are opened. They are found in each kick or at the SJB, conn. C. The LF door is GREEN/ purple in pin 11. The RF door is white in pin 12. The LR door is green in pin 8. The RR door is yellow in pin 7.
Dome Supervision blue   +   driver kick or SJB, conn. E, pin 16
The dome light wire is also found in the passenger side A pillar.
Trunk/Hatch Pin yellow/orange   -   driver kick or SJB, conn. C, pin 6
Hood Pin blue/orange   -   pin switch or SJB, conn. A, pin 27
Notes: The hood pin wire rests at ground and goes to an open circuit when the hood is opened.
Trunk/Hatch Release brown   -   switch or SJB, conn. D, pin 27
The trunk release motor wire is GREEN / WHITE (+) in the driver kick or at the SJB, conn. E, pin 23.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm PURPLE / brown   -   driver kick or SJB, conn. C, pin 5
Notes: Meter this wire while turning the key in the driver door key cylinder.
On vehicles with memory seats, the factory alarm disarm wire is found at the driver door module in the door.
Disarm No Unlock see factory alarm disarm
Tachometer NOT gray or WHITE/ blue   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire PURPLE / white   +   switch or SJB, conn. A, pin 19
Parking Brake gray/blue   -   switch or SJB, conn. C, pin 9
Horn Trigger blue/white   -   switch or SJB, conn. B, pin 6
Memory Seat 1 PURPLE / white   -   driver door module in door
Memory Seat 2 yellow   -   driver door module in door
Memory Seat 3 N/A   -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 556SW
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models.
Monday, June 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
