05 Envoy, 457G
b-roy
Copper - Posts: 56
Posted: August 05, 2006 at 1:54 PM / IP Logged
Anyone know if the 457G  does not feed out doorpin on these vehicles?
reisset
Member - Posts: 38
Posted: August 07, 2006 at 4:45 PM / IP Logged
yes they have a feature domelight supervision, you connect the dome light input wire from the bypass then the bypass will give a ground when the door will open.
Martin
Chris Luongo
Platinum - Posts: 3,746
Posted: August 09, 2006 at 7:34 AM / IP Logged
b-roy,
I'm not sure if the 457G puts out door trigger on a Trailblazer, as I have only installed one of those pieces.
But, I do know that the Trilogix GM-DLBP puts out a door trigger on its pink/white wire for ONLY the doors that have an electronic door module in them.......that is, the two front doors and the tailgage.
Since the two rear doors only have conventional switches inside, with wires running into the car, you have to either tap into those wires directly, or count on the domelight for trigger for the rear doors.
kgerry
Platinum - Posts: 3,455
Posted: August 09, 2006 at 9:49 AM / IP Logged
yes it will if connected to the domelight circuit, it will generate a negative out to go to an alarms neg door trigger circuit
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
