Compustar remote issue
Mrelecom
Member - Posts: 6
Posted: August 12, 2006 at 9:38 PM / IP Logged
Hey guys, I installed a compustar 900Fmas a few months ago, and it's been working perfectly. He just called me from out of town saying that he could disable the alarm on his MDX...
He waited for the alarm to time out and put in valet mode, so the remote is responsing, but everytime he tried to lock or unlock the doors, the remote goes through the feature sequence, you know flashing all the icons, and gives what he said looks like an error code " R8-0 "... has anyone seen this before?
I will be looking at the alarm on monday, so any help would be great..
thanks Mark
Mrelecom
Member - Posts: 6
Posted: August 13, 2006 at 1:54 AM / IP Logged
I have looked through all the info I could find, but I don't see anything about error codes on the 2 way remote, just diagnostic from the in car LED...
thanks for anyones help, Mark
Platinum - Posts: 12,488
Posted: August 13, 2006 at 9:52 AM / IP Logged
Replace the battery and make sure that the contacts of the battery inside the remote control is free of corrosion or rust. I had this happen to about a half dozen customers and it ended up being either rust on the contacts or a bad battery.
thesaint124
Member - Posts: 32
Posted: August 13, 2006 at 11:36 AM / IP Logged
thank you very much, so that error code or whatever it is, you have seen that before?
regards, Mark
awol_cool
Posted: August 13, 2006 at 4:03 PM / IP Logged
i've seen that R8-0 code before on my remote. I'm assuming it means low battery because thats what the problem turned out being.
thesaint124
Member - Posts: 32
Posted: August 13, 2006 at 6:31 PM / IP Logged
oh ok... could anyone let me know if that's what that code means for sure?  I'll be looking at the unit tomorrow, and will let you know what the problem tunred out ot be..
Mark
Posted: August 13, 2006 at 11:16 PM / IP Logged
It's a low or no battery indicator that pops up when the battery is jiggled inside the remote and momentarily looses contact with the the circuit board.
thesaint124
Member - Posts: 32
Posted: August 14, 2006 at 1:07 AM / IP Logged
Thanks very much guys... I really apreciate it. by the way, is there a listing online with the error codes like that for the 2 way remotes? just for future reference..
regards, Mark
Posted: August 14, 2006 at 8:44 AM / IP Logged
No there is not, but you can always go the the tech support at Firstech or contact the dealer where you bought the Compustar system from.
