Problem with Ultrastart not tach learning
hairbear65
Member - Posts: 13
Posted: August 28, 2006 at 11:27 AM / IP Logged
I just installed a 4560 Ultrastart unit in my 97' F350 Ford pickup. I can not get it to tach learn. I even went so far as to pull th instrument cluster out and get to the tach wire....still nothing. I keep getting 7 flashed on my parking lights noting that NO TACH SIGNAL WAS REC'D!!
Everything else seems to work.
I tied into the WHITE/ pink wire near the PCM by the drivers left foot.
Thanx Tom
KarTuneMan
Platinum - Posts: 7,056
Posted: August 28, 2006 at 11:44 AM / IP Logged
do the parking lights turn ON when going into "learn" mode (when you swist the key to ign.) before ytou start?
ALSO...where did you get your tach signal? That same color wire is behind the cluster.
hairbear65
Member - Posts: 13
Posted: August 28, 2006 at 12:04 PM / IP Logged
Yes, the parking lights come on. I tapped into the tach wire (wht/pnk) at the harness to the left of the brake pedal. I get the diagnostic code of 7 flashes from my parking lights.
swamprat323
Gold - Posts: 1,335
Posted: August 28, 2006 at 12:13 PM / IP Logged
did you meter that wire to make sure it is the tach, also what kind of conection are you using. if not striping wire back make sure the connection is good.
hairbear65
Member - Posts: 13
Posted: August 28, 2006 at 12:30 PM / IP Logged
Did not put a meter to it. I'm going off  everyone elses experience. I'm going to go out to the coil and tie in there and see what happens. Yes, The wires are stripped..all the connections I know are correct are soldered. This is a bitch..this is holding me up bad. i shuld have been doenwith this hours ago.
hairbear65
Member - Posts: 13
Posted: August 28, 2006 at 1:20 PM / IP Logged
Thank god... for Kartuneman. thanx for the help on the landline!
There are two identical wht/pnk wires running thru the same harness. One carried only mV while the other carried 5+Vdc. The system learned tach and now its cleanup time.
Thanx again Gary for your time.
Tom
KarTuneMan
Posted: August 28, 2006 at 6:19 PM / IP Logged
Baldguy here...no problem hairbear....Problem with Ultrastart not tach learning -- posted image.
iskidoo
Silver - Posts: 1,047
Posted: August 28, 2006 at 7:13 PM / IP Logged
It's always the tachs that I have a difficult time finding too. Some can be a pain to locate.
Steve G
hairbear65
Member - Posts: 13
Posted: August 28, 2006 at 7:22 PM / IP Logged
Sorry Steve!!!
ANOTHER BIG THANK YOU TO YOU!!...Shes seems to be working fine. I'm not sure th glow plug wires working....I just programmed the 15 second delay into it.
Thanx Again...
Tom
