98 accord Tach wire
profuse007
Gold - Posts: 2,015
Posted: January 16, 2003 at 3:43 PM / IP Logged
TachBlue Distributor
TACH SENSOR BLU AT COIL MOD
these two info about tach wire of 98 accord, exactly where is this wire located
brianh
Silver - Posts: 518
Posted: January 16, 2003 at 6:25 PM / IP Logged
That wire should be located under the hood of the vehicle.  Look where your spark plug wires are running from.  That will be your coil.  Good luck.  Brian
Chris Luongo
Platinum - Posts: 3,746
Posted: January 16, 2003 at 6:39 PM / IP Logged
   TACHOMETER|blue                |   |tach test connector *11
 *11 The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor.  The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot.
profuse007
Gold - Posts: 2,015
Posted: January 18, 2003 at 12:59 PM / IP Logged
i dont see white 2 pin, but i see gray 2 wire pin
Tuesday, May 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
