2006 Jeep Wrangler Wiring List
rkrumrey
Posted: September 02, 2006 at 11:14 AM / IP Logged
I am looking for a wiring list for an alarm that includes starter cut-out  for a 2006 Jeep Wrangler Unlimited.  Thanks.
gcorrea
Silver - Posts: 436
Posted: September 09, 2006 at 2:04 AM / IP Logged
wiring for an alarm or the jeep?
gcorrea
slicksam
Copper - Posts: 291
Posted: September 09, 2006 at 4:54 PM / IP Logged
a little confused on your question, but here you go....
transponder bypass required
12VOLTS  Red 2x  Ignition switch  +
IGNITION  Pink/green  Ignition switch  +
ACCESSORY  Pink / YELLOW  Ignition switch  +
STARTER  Pink/orange  Ignition switch  +
KEY SENSE  Violet/tan  Ignition switch  -
TACH SIGNAL  Blue / YELLOW  Engine coil (right of engine)  AC
DOORPIN  violet and violet/white  On each door switch  -
BRAKESWITCH  WHITE/ tan  brake pedal  +
PARKLIGHTS  WHITE/ yellow  steering column  +
HAND BRAKE  Gray/black  Right of gaz pedal  -
HORN  RED / yellow  steering column  -
CLUTCH SWITCH  Yellow/red  Above clutch pedal
Testing is the key
rocky5
Posted: September 10, 2006 at 12:49 AM / IP Logged
thanks guys for posting both the ? and the answer...just what I was lookin for yesterday!!!
