95 stratus oem alarm won't stop
andresinibus
Member - Posts: 6
Posted: September 03, 2006 at 6:38 PM / IP Logged
How exactly do you disarm the oem alarm on a 95 stratus please be specific on locations any help will be apreciated cuz car its driving me crazy and i need it for work
Twelvoltz
Platinum - Posts: 2,384
Posted: September 03, 2006 at 6:52 PM / IP Logged
Have you tried to unlock either front door with the key? This normally disarms the factory alarm when a keyfob is not available.
For a little more details on how to disarm the system DEI lists this "DODGE, STRATUS, 1995, Factory Alarm Arm Lt. GREEN/ orange from drivers door or dk. GREEN/ orange from passenger or catch either at BCM located behind right side dash. Use a positive (+) trigger thru a 940 ohm resistor to arm, and a positive (+) trigger thru a 470 ohm resistor to disarm. Must use relays."
Hope this helps.
andresinibus
Member - Posts: 6
Posted: September 06, 2006 at 11:19 PM / IP Logged
ok i got tired of this car i runned a 470 ohm current trough every single l GREEN/ orange wire i found underneath the dashboard. coming from the doors there is none (l GREEN/ orange) there is a dark GREEN/ orange on both doors but thats for the locking motor. i went to the dealer today and they are telling me that there is no OEM alarm in my car just keyless entry. if its an after market alarm where could they have hiden the brain because its not in the driver side. help please.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 07, 2006 at 7:26 AM / IP Logged
Exactly what is happening when you have the problem?
Horn sounding? Or is it a siren rather than the factory horn? Lights flashing? Parking lights or headlights?
Any signs of anything aftermarket installed, like a red LED drilled into the dash, or toggle or pushbutton switches under the dash?
Have you also tried disconnecting the battery for a couple of minutes, and then re-connecting it?
By the way, connecting stuff at random to the car's wiring is just asking for trouble.
The proper method is to first test the wire with a multimemter or even a test light if you have to, then after you're sure it's the right one, make your connections.
andresinibus
Member - Posts: 6
Posted: September 08, 2006 at 2:53 AM / IP Logged
this is exactly what happened and what keeps happening i took out the blower resistor to replace it locked the car went to the dealer came back started the car (or tryied to) the car started but it died right away the head lights stay blinking the horn stays honking, and the engine turns over but it wount start. (wierd since its usually the starter that gets cut out by the alarms) i tryed the locking unlocking of the doors, disconecting the battery usually leave it disconected over night next day same thing. no sign of after market alarm no red light no switch not even a brain and i already dissambled the hole dash board (fixed my tach on the way) and nothing Dodge says there is only a factory keyless entry installed in my car but no OEM alarm and i know abouth connecting wires, i only do the l green orange ones i see. its just im so desperated and going crazzzy.
black cavy
Copper - Posts: 78
Posted: September 08, 2006 at 11:04 AM / IP Logged
What model isit
im going to do a serch and see wht i can find
may i ask where the factory key fab is,i mean it sounds like its gone unprogramed
cooooldman
Posted: September 10, 2006 at 12:29 AM / IP Logged
Have you made sure your battery isnt dead, also check all your fuses just to make sure your getting ignition voltage.even the ones under the hood.
oldschool in ky.
andresinibus
Member - Posts: 6
Posted: September 10, 2006 at 4:41 PM / IP Logged
i checked all fuses they are good bsttery aint dead it still turns the engine it wount start but it turns it. and its a 95 dodge stratus 2.4L auto. thanks guys
andresinibus
Member - Posts: 6
Posted: September 25, 2006 at 1:44 AM / IP Logged
I took out the BCU today and there is a VTD (vheicle theft deterent) system on it any ideas how to dissarm this SOB there is got to be a way right   :waah: right or if anybody has accses to alldata i will really apreciate the diagrams for the keyless entry and VTD or alarm. 95 dodge stratus L4 2.4 litters automatic Thanks everyone.
new battery btw.
andresinibus
Member - Posts: 6
Posted: September 25, 2006 at 1:45 AM / IP Logged
BTW what can activate the VTD system
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
