Manual Start
lowfront
Member - Posts: 28
Posted: September 10, 2006 at 7:26 AM / IP Logged
I know that its possible to get a manual start with a remote start up.
But I Don't know if there's a good security system that can have the manual remote start up.
Like viper or clifford? Is there a model that does this?
cutlass013
Copper - Posts: 95
Posted: September 10, 2006 at 8:20 AM / IP Logged
you have a manual transmission? well YOU can hook it up with all of them but circuit city or best buy or places like that wont because on a manual people have a tendenncy to leave them in gear so if they remote start that thing it takes off they dont wanna be held responsible there are some that say can be used on manuals but they all can
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: September 10, 2006 at 11:50 AM / IP Logged
Peripheral makes a device called the "NSS" that will allow remote starts to work safely with your manual transmission vehicle. You have to turn on the remote start before getting out of the vehicle, and the unit shuts the vehicle off when you arm the alarm. It then monitors the doors and won't remote start if a door has been opened.
My old Clifford Ace 7500 did the same thing as that Peripheral piece. My new Clifford Solaris 5 was supposed to be manual transmission compatible, but it's not.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 10, 2006 at 12:27 PM / IP Logged
www.compustar.org
www.astroflex.com        ALL of these manufacturers make manual safe remote start and security combo's.
www.ultrastarters.com
asianjack
Member - Posts: 30
Posted: September 11, 2006 at 3:16 AM / IP Logged
i have a manual remote start. i have the compustar alarm, works great and i have it set to where the car stays on when i take the key out the ignition, but then turns off when i shut the door. helps me remember to keep the car in neutral.
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
