Scion TC 2007 Wiring Diagram
melvinchau
Posted: September 16, 2006 at 5:53 PM / IP Logged
Does anyone have the Scion TC 2007 wiring diagram?
hello there
gcorrea
Silver - Posts: 436
Posted: September 16, 2006 at 6:29 PM / IP Logged
12volts
      red (30A), white (25A)
      ignition harness
Starter      black       +       ignition harness
Second Starter      green       +       ignition harness
Ignition      blue       +       ignition harness
Second Ignition      yellow       +       ignition harness
Third Ignition      N/A
Accessory      gray       +       ignition harness
Second Accessory      N/A
Keysense      black       -       ignition harness
Power Lock      green to blue       -       driver kick, 20 pin plug, pin 15
Power Unlock      purple to pink (double pulse)       -       driver kick, 20 pin plug, pin 14
Lock Motor      blue to brown       5wi      driver kick, gray 7 pin plug, pin 6
Unlock Motor      pink to blue       5wi      driver kick, gray 7 pin plug, pin 5
Parking Lights+      brown       +       top of fuse box, 30 pin plug, pin 29
Parking Lights-      brown       -       headlight switch
Hazards      orange       -       hazard light switch
Turn Signal(L)      yellow       +       top of fuse box, 30 pin plug, pin 27
Turn Signal(R)      green       +       top of fuse box, 30 pin plug, pin 28
Reverse Light      pink       +       top of fuse box, 14 pin plug, pin 2
Door Trigger      orange (D), blue (P)       -       top of fuse box
Dome Supervision      blue       -       L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin      purple       -       top of fuse box, 30 pin plug, pin 7
Hood Pin      N/A
Trunk/Hatch Release      orange       -       driver kick, gry 12 pin plug, pin 12
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      use key sense wire
Tachometer      black       ac       data link conn. under dash, pin 9
Wait to start      N/A
Brake Wire      blue       +       brake pedal switch
Parking Brake      black       -       parking brake switch
Horn Trigger      white       -       horn switch
Memory Seat 1      N/A
Memory Seat 2      N/A
M
gcorrea
gcorrea
Silver - Posts: 436
Posted: September 16, 2006 at 6:30 PM / IP Logged
this is the 06 the 07 should be the same.
gcorrea
melvinchau
Posted: September 16, 2006 at 6:49 PM / IP Logged
Thanks gcorrea, but can we be positive that the 06 and 07 wirings are exactly the same?
hello there
gcorrea
Silver - Posts: 436
Posted: September 16, 2006 at 11:09 PM / IP Logged
look for the wires and test them with a voltmeter.
gcorrea
gcorrea
Silver - Posts: 436
Posted: September 16, 2006 at 11:10 PM / IP Logged
you should always double check your wires regardless of wher you get your iformation.
gcorrea
