2006 acura rsx and tl schematics
davelamchop
Posted: October 04, 2006 at 1:01 PM / IP Logged
I'm in need of the schematics for an Acura TL and RSX for a remote start install. Any helt will be appreciated. Thanks
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 11:04 PM / IP Logged
what year never mind i see it been a long day let me look
here you go
WIRING INFORMATION - ACURA / TL / 2006 / Remote Start
[PRINT THIS PAGE]
12volts white (50A)  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red  +  ignition harness
Second Accessory WHITE/ red  +  ignition harness
Keysense RED / white  -  ignition harness
Power Lock pink/black  -  green plug, left side of fuse box
Notes: These wires will meter when using the passenger door lock switch.
Power Unlock pink/blue  -  green plug, left side of fuse box
Lock Motor yellow/black  5wi green plug, front of fuse box
Unlock Motor YELLOW /GREEN  5wi green plug, front of fuse box
Parking Lights+ RED / black  +  large white plug, top of fuse box
Parking Lights- RED / black  -  headlight switch in column cover
Hazards GREEN/ red  +  large white plug, top of fuse box
Turn Signal(L) RED / blue  +  large white plug, top of fuse box
Turn Signal(R) white  +  large white plug, top of fuse box
Reverse Light green  +  driver kick, harness to rear
Door Trigger see notes  -  rear of fuse box
Notes: The LF door is green in a 16 pin plug, pin 15. The RF door is lt. GREEN/ red in a 14 pin plug, pin 12. The LR door is GREEN/ YELLOW in a 16 pin plug, pin 14. The RR door is GREEN / WHITE in a 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome Supervision GREEN/ red  -  green 5 pin plug, rear of fuse box
Trunk/Hatch Pin blue / YELLOW  -  green plug, left side of fuse box
Hood Pin yellow/red or GREEN/ black  -  hood pin switch in latch
Trunk/Hatch Release YELLOW /GREEN or blue/black  +  driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm blue/white to WHITE/ red  -  driver door module in door
Factory Alarm Disarm BLACK/ red to white  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer NOT yellow/black  ac  any fuel injector
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN/ orange  -  large white plug, top of fuse box
Horn Trigger GREEN/ YELLOW  -  horn switch
Memory Seat 1 blue / YELLOW  -  driver door module in door
Memory Seat 2 RED / yellow  -  driver door module in door
Memory Seat 3 N/A  -
2006 acura rsx and tl schematics -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / yellow, data wire is RED / blue and ignition wire is BLACK/ green.
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 11:12 PM / IP Logged
WIRING INFORMATION - ACURA / RSX / 2006 / Remote Start
[PRINT THIS PAGE]
12volts white (40A)  +  ignition harness
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Keysense RED / white  -  ign harn or security control unit
Notes: The security control unit is to the left of the steering column.
Power Lock WHITE/ blue  -  driver kick, door harness
Notes: Also found at the multiplex control unit on the back of the fuse box in a 13 pin plug, pin 12.
Power Unlock WHITE/ green  -  driver kick, door harness
Notes: Also found at the multiplex control unit on the back of the fuse box in a 13 pin plug, pin 10.
Lock Motor yellow/black  5wi driver kick, door harness
Unlock Motor YELLOW /GREEN  5wi driver kick, door harness
Parking Lights+ RED / black or RED / yellow  +  fuse box
Parking Lights- blue  -  switch or security control unit
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red  +  turn signal switch
Turn Signal(R) GREEN/ YELLOW  +  turn signal switch
Reverse Light green  +  kick panel, harness to rear
Door Trigger green (D), lt. GREEN/ red (P)  -  security control unit
Notes: Use both wires and diode isolate each.
Dome Supervision GREEN/ red  -  driver A pillar
Notes: Also found at the rear of the fuse box in a 12 pin plug, pin 7.
Trunk/Hatch Pin red  -  security control unit
Hood Pin GREEN/ black  -  security control unit
Trunk/Hatch Release N/A
Factory Alarm Arm WHITE/ red  -  security control unit
Notes: Meter this wire while turning the key in the driver door key cylinder.
May need to use relay in certain applications.
Factory Alarm Disarm white  -  security control unit
Tachometer blue  ac  ECM/PCM, white 31 pin plug, pin 25
Notes: The ECM/PCM is under the glove box.
Also found at the fuse box, top left, 8 pin plug, pin 5.
Can also go to any fuel injector and use the wire that is NOT yellow/black.
Wait to start N/A
Parking Brake GREEN/ orange  -  parking brake switch
Horn Trigger orange  -  horn switch
Notes: The horn trigger at the security control unit is green.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / yellow, data wire is RED / blue and ignition wire is BLACK / YELLOW.
The Shagmaster
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
