96 suburban ignition wire problems
12voltlover
Member - Posts: 16
Posted: January 20, 2003 at 9:22 PM / IP Logged
We did a remote start on a 96 suburban over the weekend and it came back with a transmission shifting problem only after remote starting.  I figured the little white ignition wire was not powered so I went to the customer's house to fix it real quick.  The only wires in the ignition harness were red +12v, pink-ign, pink/wht-ign, org-ign, brn-acc, yell-start.  There was no white wire.  Does anyone know what I need to do to fix this ????
RufNUSD
Copper - Posts: 184
Posted: January 20, 2003 at 9:34 PM / IP Logged
Pink/white in a GM???? Orange tested as ignition??? It sounds like your looking at the DEI satellite relay colors not the GM wire colors. Hmmm?96 suburban ignition wire problems -- posted image.
Someone pass me that bottle.
themagicone
Silver - Posts: 325
Posted: January 20, 2003 at 10:48 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow or purple    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|   THIRD IGNITION|pink/white *1       |+  |ignition harness
*1 The pink/white does not exist on all models.
themagicone
Silver - Posts: 325
Posted: January 20, 2003 at 10:49 PM / IP Logged
|        ACCESSORY|orange              |+  |ignition harness
