Siren Problems
graysand3220
Posted: October 10, 2006 at 12:12 AM / IP Logged
I'm working on a 1997 Ford F-250 and I'm having problems with the main siren.
I have the main siren mounted above the driver side fender under the hood facing down and two mini piezo's in the a/c vents. I have fried my main siren some how. Its not a wiring issue as far as I know because it worked fine for 3 days until it rained. Then the main siren failed to work. It can't be water damage because I have seen the sirens completely submerged in water for 5 minutes and still completely fuction as normal.
I have also been told that I need to diode isolate the mini piezo's and the siren but on another truck (1996 Ford F-150) we have 2 main sirens and 2 mini piezo's of which are not diode isolated on and it has never had a problem. This truck also has a main siren mounted underneith the bed and it constantly exposed to water and still has never once had a problem.
Any Ideas or ways to troubleshoot the issue??
Me.
graysand3220
Posted: October 10, 2006 at 12:14 AM / IP Logged
I forgot to include that the alarm that the truck is equipped with is the viper 350hv.
Me.
shaggy12volt
Copper - Posts: 164
Posted: October 10, 2006 at 1:13 AM / IP Logged
when i do mutible sirens this what i doget a relay and  take your positve siren output from your brain to 86 ---12volts fused to 87 ---ground to 85 ---the sierns input to 30
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
snotdobbs
Copper - Posts: 148
Posted: October 10, 2006 at 7:49 PM / IP Logged
yeah use a relay in multiple siren setups.....try another siren.......bah
alex1525
Member - Posts: 16
Posted: October 13, 2006 at 9:37 PM / IP Logged
May the problem be the heat that is frying your siren?
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
