89 Jeep, remote start
scottie18
Member - Posts: 10
Posted: October 13, 2006 at 1:53 AM / IP Logged
hey, just a question here for my 89 jeep yj, i have wired in a car alarm/remote start, and i was just having a little problem with the remote start and am looking for a little help if someone could.  wen i hit the button on the remote it take a second but it does turn the engine over , it attemps three times but it will not not let the engine run, i know i missed an wire on the relay but in the book it went to the "star Motor" and i was unsure so i just left it alone.  now i thought it might be the alternator wire, because i just ran it to the back of the alernator on the postitive output. so if anyone with one knowledge in this area could let me know if i  have done something wrong it would be greatly appretiated,
thanks alot,
scott
Twelvoltz
Platinum - Posts: 2,384
Posted: October 13, 2006 at 7:22 AM / IP Logged
What is the Make and Model of system you are trying to install?
scottie18
Member - Posts: 10
Posted: October 13, 2006 at 10:12 AM / IP Logged
it is the, Nirto- 2way fm car alarm with remote start, doesnt really have a model number and i bought it off the internet everything else works great just the starter is buggin up
alex1525
Member - Posts: 16
Posted: October 13, 2006 at 9:17 PM / IP Logged
Does your car have  anti-theft  chip?  if it does then you need a immobilizer interface transponder in oder to start  your car without the key in the ignition switch.
the best way to find out is leaving the key in the ignition switch(just leave it in, dont turn it) and then try to remote atart your car, if it start buy the transponder!
scottie18
Member - Posts: 10
Posted: October 14, 2006 at 4:25 PM / IP Logged
an 89 jeep yj with a transponder chip?? i dont think so man
scottie18
Member - Posts: 10
Posted: October 21, 2006 at 1:11 PM / IP Logged
i just installed a remote starter on my 89 jeep yj with a manual transmission and i was woundering if anyone could tell me a few starter sequences to try out cause the book never said any, but yes that would be great thanks guys
scott
xtremej
Gold - Posts: 1,440
Posted: October 21, 2006 at 1:34 PM / IP Logged
On a ultra start it goes like this:   prking brake applied trans in neutral foot off the brake pedal, then push the brake pedal 2 times the remote start will flash the pkg lights 3 times to indicate it is ready to go, you then take the key out of the ignition and get out of the car it will continue to run until the door is closed (works off the door pin) it is then able to be remote started.
scottie18
Member - Posts: 10
Posted: October 22, 2006 at 4:21 PM / IP Logged
yea i really forgot in include that its actually nitro bmw2-way car alarm with remote start and that last sequence did not work,  if there is any other ideas that would be great
Friday, May 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
