05 subaru forester diagram
greggsymington
Member - Posts: 7
Posted: November 10, 2006 at 8:38 PM / IP Logged
Hope one of you guys have a diagram for an 05 subaru forester. Planning a remote start install. Thanks in advance.
lsondubz
Copper - Posts: 193
Posted: November 11, 2006 at 9:03 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SUBARU / FORESTER / 2005 / Remote Start
12volts      white (50A)       +       ignition harness
Starter      WHITE/ blue       +       ignition harness
Second Starter      N/A
Ignition      green       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow       +       ignition harness
Second Accessory      N/A
Keysense      WHITE/ red       +       ignition harness
Power Lock      RED / white       -       integrated module, gray plug
Notes: The integrated module is to the left of the steering column.
Power Unlock      yellow/red       -       integrated module, gray plug
Lock Motor      lt. GREEN/ black       5wi      integrated module, blue plug
Unlock Motor      red       5wi      integrated module, blue plug
Parking Lights+      BLACK/ red or orange       +       parking switch
Parking Lights-      BLACK/ pink       -       lighting switch
Notes: The negative parking lights wire only works with the ignition on.
Hazards      same as turn signal wires
Turn Signal(L)      BLACK/ green       +       turn signal switch or keyless
Notes: The keyless entry control module is above the passenger kick panel.
Turn Signal(R)      lt. GREEN/ black       +       turn signal switch or keyless
Reverse Light      BROWN / yellow       +       passenger kick, harness to rear
Door Trigger      yellow       -       integrated module, gray plug
Dome Supervision      use door trigger wire
Trunk/Hatch Pin      common with door trigger wire
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      factory remote only
Tachometer      green       ac       ECM, 35 pin plug, pin 10
Notes: The ECM (Engine Control Module) is below the glove box. The tach wire is also found behind the instrument cluster in the middle plug.
On the turbo models, the tach wire is in the 34 pin plug, pin 23.
Wait to start      N/A
Brake Wire      WHITE/ black       +       brake pedal switch
Parking Brake      lt. green to lt. GREEN/ black       -       parking brake switch
Horn Trigger      RED / green       -       horn switch or keyless
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on the 2.5 XT models.
lsondubz
Copper - Posts: 193
Posted: November 11, 2006 at 9:04 AM / IP Logged
Second Starter      N/A
Second Ignition      N/A
Third Ignition      N/A
Hood Pin      N/A
Wait to start      N/A
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Yes      Type:
Transponder
Part #: 556UW
