2007 escalade alarm
llsid2kll
Member - Posts: 7
Posted: November 15, 2006 at 4:10 PM / IP Logged
Im just giving the heads up on the 2007 cadallac escalade alarm, its a real pain, if you havent done it, try not to. 7 relays are needed, and wires need to be run into the two front doors so charge accordingly, also dont forget the factory alarm disarm wire in the drivers door. Directechs is pretty good with the wiring, but test everything there were 4 wire colors different. I would charge at least an extra 275 for the job but thats just me, it took about 5 hours for a basic alarm.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2006 at 4:33 PM / IP Logged
Can you elaborate on your relay set up and all the wiring inside the doors.
sparkie
Platinum - Posts: 2,061
Posted: November 15, 2006 at 6:47 PM / IP Logged
Save yourself a lot of grief. Get a XK01-GMDL6 module for the door locks/alarm interface and a XK06-PKG9 for the starter interface. No extra relays or wiring into the door. Everything is done through data. Get them from bypasskit.com.
sparky
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
