2006 Dodge Caravan, alarm/remote start
knows_better
Posted: November 16, 2006 at 8:21 PM / IP Logged
Hi guys, I plan to install an alarm/remote start in a 2006 Caravan this weekend and I'm looking for the wiring information. Any information would be greatly appreciated.
Mike M2
Platinum - Posts: 2,652
Posted: November 16, 2006 at 8:43 PM / IP Logged
12volts lt. blue/red (10A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory NOT required for remote start
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green  -  BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed interface modules.
Power Unlock same as power lock wire
Lock Motor tan/white  5wi BCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green  5wi BCM, green plug, pin 28
Parking Lights+ WHITE/ brn (L), WHITE/ org (R)  +  driver kick, harness to rear
Parking Lights- WHITE/ brown  -  switch or BCM, gray plug, pin 21
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
Hazards WHITE/ dk. blue  -  switch or BCM, gray plug, pin 31
Turn Signal(L) wht/lt blu (F), wht/dk grn (R) +  BCM, green plug, pins 1, 2
Turn Signal(R) WHITE/ tan (F), WHITE/ brown (R) +  BCM, green plug, pins 3, 4
Reverse Light WHITE/ lt. green  +  BCM, green plug, pin 9
Door Trigger see notes  -  BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervision yellow/brown or yellow/white  +  BCM, white plug, pin 33
Trunk/Hatch Pin PURPLE / orange  -  BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue (export only)  -  BCM, white plug, pin 30
Trunk/Hatch Release PURPLE / tan  -  BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.o notes.
Power Sliding Door PURPLE / dk. blue  -  BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT BROWN / white  ac  ign. coil pack or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake dk. GREEN / WHITE  -  parking brake switch
Horn Trigger dk. GREEN/ purple  -  horn switch
Memory Seat 1 PURPLE / brown  -  BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2 same as memory seat 1 wire  -
Memory Seat 3 N/A  -
2006 Dodge Caravan, alarm/remote start -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556CW
Mike M2
Tech Manager
CS Dealer Services
knows_better
Posted: November 16, 2006 at 8:51 PM / IP Logged
Thank you Mike M2.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
