Viper 791XV cranks during Valet Take-Over
jnice
Member - Posts: 6
Posted: December 05, 2006 at 9:46 PM / IP Logged
I just got done installing the alarm in my Cherokee. For some reason (not everytime) when I perform the Valet-TakeOver, it cranks until I shut it down by brake etc.
I press the * button twice, and sometimes it will go back into remote start like it should, other times it just cranks! Anyone have any experience with this?
Do it right the first time
mauri197
Copper - Posts: 80
Posted: December 05, 2006 at 10:52 PM / IP Logged
make sure you have the correct tach wire i had that happen to me once my connection on my tach wasnt so ggod it would see sometimes and sometimes it wouldnt especially when i tried to do pit stop sounds like a tach problem to me but double check everything what year cherroke is this
jnice
Member - Posts: 6
Posted: December 06, 2006 at 8:12 PM / IP Logged
It is a 96. Yeah I thought that too at first, but when I did the tach learning it was good, led came on steady like it should. Shouldn't the alarm know that it is running from the ignition wires? I know it senses the tach, but it should know that it is already running and not crank right?
cntrylvr79
Silver - Posts: 582
Posted: December 06, 2006 at 8:32 PM / IP Logged
Where'd you pick up the tach signal?  Is it a regular cherokee or grand cherokee?
Cause I'm So white and nerdy...
First Class Certi-fried installer
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
