2007 Ford Fusion remote start?
bbtaco
Copper - Posts: 119
Posted: December 06, 2006 at 8:57 AM / IP Logged
Has anyone installed a rs on a Ford Fusion? Anything to watch out for? Can the bypass wires be gotten to under the dash or would I have to go to the key cylinder?
Mike M2
Platinum - Posts: 2,652
Posted: December 06, 2006 at 5:45 PM / IP Logged
I did one 2 weeks ago, very easy car to do. I used a 556S for a bypass, worked great....
Mike M2
Tech Manager
CS Dealer Services
bbtaco
Copper - Posts: 119
Posted: December 06, 2006 at 6:15 PM / IP Logged
Is the steering column cover hard to get off to get to access the wires at the key cylinder? I don't have the car nearby to look at it. What rs unit did you install?
NowYaKnow
Gold - Posts: 1,217
Posted: December 06, 2006 at 10:05 PM / IP Logged
Very easy vehicle.. Shroud comes off easy.. Keys have the keyless built into them so your best bet is just to sell them a stand alone system with a smaller remote.
Mike
tbone587
Copper - Posts: 167
Posted: December 06, 2006 at 10:52 PM / IP Logged
yup I did one of these as well.  Very easy car.  I used a 556uw for mine.
Mr_Fusion
Copper - Posts: 113
Posted: December 07, 2006 at 12:36 PM / IP Logged
What did you guys use for OEM arm/disarm? At the time I installed in a Zephyr, (same as Fusion) my diagrams listed the arm/disarm wires but it turned out that these wires were for lock/unlock only and did not affect the OEM alarm at all.
skeeler
Member - Posts: 32
Posted: January 15, 2007 at 9:53 AM / IP Logged
I also have a 2007 Ford Fusion. I am planning on in stalling a Bulldog Security Remote start unit. Model Deluxe 500. If I do a stand alone starter like this, do I need anything special (other than the kit), or need to know anything about installing this? Thanks, Shawn
Platinum - Posts: 12,488
Posted: January 15, 2007 at 11:25 AM / IP Logged
VIOLET/BROWN Pin #5 at connector C - At the SJB (Smart Junction Box) which is part of the fuse/relay box under the driver side dash.
On vehicles with memory seats, the factory alarm disarm wire is found at the driver door module in the door.
skeeler
Member - Posts: 32
Posted: January 15, 2007 at 11:41 AM / IP Logged
I am looking at doing the remote start only. No door locks (using the factory lock/unlock). Will I need anything else, other than what comes with the standard kit? Or need to do anything special? Thanks.
Mike M2
Posted: January 15, 2007 at 5:05 PM / IP Logged
You need a bypass kit of course...
Mike M2
Tech Manager
CS Dealer Services
