cs-2016fm, 01 chevy s-10 crew cab
splyce
Posted: December 09, 2006 at 12:36 AM / IP Logged
Need some guidance on how to install this system.  What extra parts will I need (relays, bypasses, etc) and where can I get the extras if needed?  Or is there anyone in the Quad Cities (Iowa/Illinois area) that could help with the install?  Any help would be appreciated.  I am an electronics technician on amusement equipment so I have the basic understanding for working with the install, but I am not familiar with automotive electronics enough to be comfortable installing this system without all the details.  I have had this system for a year and would really like to get it installed.  If you are from my area, please respond via emai.
Brian
KarTuneMan
Platinum - Posts: 7,056
Posted: December 09, 2006 at 12:41 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES PASSLOCK 2   SEE NOTES
 12 VOLTS Red Ignition harness   +
 IGNITION Pink Ignition harness   +
 IGNITION 2 White Ignition harness   +
 ACCESSORY Orange Ignition harness   +
 STARTER Yellow or Purple Ignition harness   +
 KEY SENSE Lt.green Ignition harness   -
 TACH SIGNAL White At coil on engine   AC
 Top of engine on passenger side
 LOCK Lt.blue In driver's kickpanel   +
 If the vehicle is equipped with a keyless entry system the doorlocks are positive trigger, otherwise they are reverse polarity.
 UNLOCK White In driver's kickpanel   +
 DRIVER LOCK MOTOR Gray 72-pin plug left of steering column   +
 DRIVER UNLOCK MOTOR Tan 72-pin plug left of steering column   +
 PASSENGER UNLOCK MOTOR Tan 72-pin plug left of steering column   +
 DOORPIN Purple At light switch harness   -
 To arm factory alarm, pulse the TAN ( - ) wire at the driver's side doorpin at the same time as the lock wire.
 FACTORY ARM Tan At driver's side doorpin   -
KarTuneMan
FACTORY DISARM Lt.green Above driver's kickpanel   -
 BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   +
 HAND BRAKE Lt.blue On park brake bracket   -
 HORN Black At steering column harness   -
 CLUTCH SWITCH PURPLE / white At switch on top of clutch pedal   TYPE 1
 DRIVER WINDOW UP Dk.blue At switch in driver's door   REV POL
 DRIVER WINDOW DOWN Brown At switch in driver's door   REV POL
 PASSENGER WINDOW UP Blue or Blue/white At switch in driver's door   REV POL
 PASSENGER WINDOW DOWN Tan At switch in driver's door   REV POL
 HEADLIGHTS Yellow At light switch harness   +
 REVERSE LIGHTS Lt.green At steering column harness   +
 DIMMER Dk.green At dimmer switch harness
 VSS WIRE Dk.GREEN / WHITE VCM in riht front engine comparment   4000ppm
 On the 2.2L, this wire is found at pin-16 of the C2 80-pin connector. On the 4.3L, it is located at pin-3 of the 24-pin BLACK connector.
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
 PASSLOCK DATA Yellow In 3 wire harness from ignition switch   DATA
 PASSLOCK GROUND Black or ORANGE / black In 3 wire harness from ignition switch   -
Available Notes
Vehicle Notes
PLEASE NOTE: Equipped with PASSLOCK II anti-theft system, see security diagram. For remote start installation, it will be necessary to pulse the TAN (driver's doorpin wire) to shut off the RAP system or the radio and accessories with stay on after the remote starter has shut down. Use you remote starter's rearm wire or any wire that provides a pulse after shutdown. SECOND IGNITION must be connected for remote start or the transmission computer will shut down ( engine light comes on ), and the vehicle will not shift properly.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
