04 durango, remote start
prm99v6
Posted: December 10, 2006 at 6:22 PM / IP Logged
OK
04 durango st, 4.7 no sentry key, remote start 562t, 456l for door locks....starts everytime, and locks work fine but the check engine light came on. I am guessing that it is because I did not hook up the 2nd access wire.  there are 2 ign, and 2 acces. Do both access need to be hooked up. If so, i hook a relay up to the ribon cable wire for accessory for 2nd access?also, how do i relay isolate the parking light wire? i checked the relay guide on this site and am unsure of what one to use.
thanks for the help
Twelvoltz
Platinum - Posts: 2,384
Posted: December 10, 2006 at 6:46 PM / IP Logged
Yes, you will have to power up the extra accessory to get the light to turn off. Use the pink and pink/white of the 562t to the ignitions, the orange to accessory one and wire up a relay for accessory two activated by the - accessory output of the 562t (the orange wire in the ribbon cable).
As far as the parking lights go, use the negative instead much easier, serves the same purpose and draws less current. It is pink/red at the headlight switch. Make sure you change the light flash polarity jumper and you'll be good to go.
Platinum - Posts: 12,488
Posted: December 10, 2006 at 7:13 PM / IP Logged
Parking lights are negative trigger thru a 1100 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
prm99v6
Posted: December 10, 2006 at 7:27 PM / IP Logged
so how would i do that? the white wire goes into what pin on the relay? and what are the rest of the pin outs. Where does the resistor go?
Posted: December 10, 2006 at 7:34 PM / IP Logged
Parking Light Isolation
prm99v6
Posted: December 10, 2006 at 7:42 PM / IP Logged
thanks for your help, i missed that on directechs
dangerousdarren
Member - Posts: 14
Posted: December 11, 2006 at 12:44 AM / IP Logged
The way I do the resistive parking lights on the Chrysler products is by running the + parking light output up to the front drivers side parking light assembly and hooking into the + wire there. Usually less hassle that way. No relays or risisters, just a direct connection.
Darren
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
