Jeep Wrangler Alarm Recommendations
lj-rubi
Posted: December 11, 2006 at 10:16 AM / IP Logged
I have a 2005 Jeep Wrangler. I have used the search function, but I did not find the answers to me questions. Can someone please recommend a system that meets the following requirements:
- 2-way paging
- proximity sensor (radar, microwave, what do I use?)
- no need for remote start
- keyless entry (I have aftermarket door locks)
- may be installed by someone with a basic understanding of electronics and above average DIY skills.
Can you also recommend a source and and detail any recommended options? Lastly, I am considering the Hornet 745T, but I have no first hand knowledge of systems. Thanks!!!!!!!!!!!
mobilecustoms
Silver - Posts: 397
Posted: December 11, 2006 at 10:38 AM / IP Logged
viper 5000 alarm and keyless
or the viper 791 or 5900 with remote start keyless and alarm
can add prox sensor tilt, glass anything you want
takes time but well worth it in the end.
not too bad of a car to work on.
mobilecustoms
Silver - Posts: 397
Posted: December 11, 2006 at 10:39 AM / IP Logged
PART   COLOR LOCATION DIAGRAM
12 VOLT CONSTANT   RED (+)    IGNITION SWITCH HARNESS
STARTER PINK/ORANGE (+)   IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 PINK/LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 PINK / YELLOW (+) (14 Gauge wire)   IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) WHITE/ YELLOW (+)   @ HEADLIGHT SWITCH or in DRIVERS KICK PANEL
POWER LOCK ADD ACTUATORS   TO BOTH DOORS, See DIAGRAM   14301_WRANGLER_ACTUATOR DIAGRAM JBS UNITS.pdf
POWER UNLOCK ADD ACTUATORS   TO BOTH DOORS, See DIAGRAM   14301_WRANGLER_ACTUATOR DIAGRAM ALERT SHELBY UNITS.pdf
LOCK MOTOR WIRE N/A
DOOR TRIGGER PURPLE (-) and PURPLE / YELLOW (-) Use both, See NOTE *1   IN DRIVERS KICK PANEL, See DIAGRAM   14301_WRANGLER_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION YELLOW/ORANGE (-), Requires Part #775 Relay   @ UNDER DASH LIGHT
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN RED / YELLOW (-)   IN DRIVERS KICK PANEL
TACH Any wire NOT BROWN or PINK/GRAY   @ any FUEL-INJECTOR or IGNITION COIL
WAIT TO START LIGHT N/A
BRAKE WHITE/ TAN (+)   @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM   N/A
ANTI-THEFT CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM   TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 this vehicle has (2) DOOR TRIGGER wires, a PURPLE (-) for the DRIVERS door and a PURPLE / YELLOW (-) for the PASSENGER door. When connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
LINK 1 LINK TEXT 1 LINK 2
lj-rubi
Posted: December 11, 2006 at 2:24 PM / IP Logged
Thanks MobileCustoms for the quick response! After a little research it seems that the Viper systems you mention are designed for dealer install, is that correct? Are they superior to the Hornet 745 that I was considering which is apparently designed for self installation? Is there a good source online for the Viper systems? Thanks again!!
mobilecustoms
Silver - Posts: 397
Posted: December 11, 2006 at 3:25 PM / IP Logged
try to find a dealer that will sell to you
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
