viper 160XV, 2005 suzuki forenza
jeffdady
Posted: December 12, 2006 at 12:34 PM / IP Logged
Hello,
I have just tried to install a viper 160xv into a 2005 suzuki forenza.  I have everything hooked up and when i hit the start button nothing happens.   All wires seem to be hooked up correctly.
05gt
Silver - Posts: 628
Posted: December 12, 2006 at 12:44 PM / IP Logged
The vehicle doesn't have a factory immobilizer, basically just go over and recheck that all the connections are done properly
05gt
Silver - Posts: 628
Posted: December 12, 2006 at 12:45 PM / IP Logged
have you programmed the tach yet???
jeffdady
Posted: December 12, 2006 at 3:32 PM / IP Logged
I dont think i got the right tech, I dont know where to find it.  Any Help?
05gt
Silver - Posts: 628
Posted: December 12, 2006 at 4:32 PM / IP Logged
the wire is grey and it is behind the instrument cluster, and it is also at the ECM
the ecm is in the engine compartment attached to the middle area of the firewall and is also grey
jeffdady
Posted: December 12, 2006 at 8:56 PM / IP Logged
I got it working!!! Thanks for the help!  I didn't know that the wires are numbered going to the ecm.  There were three greys and i now have the correct one, thanks again
jeffdady
Posted: December 19, 2006 at 12:40 AM / IP Logged
I have a question on the locks now.  There is a feature on the door where if you lock it when the drivers door is opened, it will unlock so you have to use the key to lock the door. Is there a wire i need to ground so the doors will stay locked if the door is open and i use the remote locks?
