Using test light and computer damage??
king244
Copper - Posts: 68
Posted: January 28, 2003 at 10:16 PM / IP Logged
Hi...I will be installing alarm, remote start w/ doorlocks in a 2001 dodge ram 1500.....
My question is if I am using my trusty old testlight do I have to worry about damaging the computer or setting off the airbags....?
Any other info would help also since I havent had any recent installs with newer vehicles....
emorse2323
Copper - Posts: 106
Posted: January 28, 2003 at 10:32 PM / IP Logged
yes there's a possiblity, the best thing to use is a digital multimeter.
camino
Copper - Posts: 54
Posted: January 30, 2003 at 8:10 PM / IP Logged
o say yes,theres a special test lght from snap on,there are very food and safemyou can test posirive and nevative qith those
el camino
camino
Copper - Posts: 54
i sa yes,theres a special test lght from snap on,there are very food and safemyou can test posirive and nevative qith those
el camino
auex
Platinum - Posts: 5,041
Posted: January 30, 2003 at 9:24 PM / IP Logged
For the most part the circuit safe test lights are safe but they still pass a little bit of current.  For example they can make the horn honk a little and even on a vehicle such as a 99 chevy impala the test light will pass enough current to crank the engine ( with the key in the run position, vehicle has a computer controlled start).  If there is any reason to worry then the best thing to do is to use a DMM.  They have the possibility to blow an airbag but I doubt that they will cause a computer to blow up.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
