98 explorer remote starter
sickstyles
Member - Posts: 34
Posted: January 29, 2003 at 5:16 PM / IP Logged
Looking for help with a avital 3300 install in a 98 explorer with the anti theft system. Can it be disarmed and not used anymore without a module? or do i have to retain it and use the module?????
zargon
Copper - Posts: 186
Posted: January 29, 2003 at 6:36 PM / IP Logged
I imagine it could be removed but wouldbe expensive and maybe hard I would keep it since it is a very good theft deterent.
zargon ruler of estranorth
securinu
Silver - Posts: 772
Posted: January 29, 2003 at 10:05 PM / IP Logged
find the disarm wire dark green /violet and ground it  verify with key and meter.
sickstyles
Member - Posts: 34
Posted: January 30, 2003 at 12:17 PM / IP Logged
Thanks for the help, i figured it out lastnight. Jusy glad someone else had the same idea.
andy
Chris Luongo
Platinum - Posts: 3,746
Posted: January 30, 2003 at 3:39 PM / IP Logged
Also, look up above the brake pedal, off to the left.  See the big black thing that looks like a suitcase handle?  See the thick wire harness above it?  You can get the tan / YELLOW tach wire in there.
IT Lbs
Member - Posts: 8
Posted: January 30, 2003 at 4:16 PM / IP Logged
Also you can grab the tan / YELLOW tach wire in the driver's kick along with a - hood pin wire that is tan/green
