1996 Olds 88 tach wire
greenenvy22
Posted: January 06, 2007 at 10:56 AM / IP Logged
I'm installing a remote starter/keyless/alarm unit on my 1996 olds 88.
I have the door locks working, and  the starter is almost working. I have not been able to find the tach wire to hook that into the remote starter, and I believe this is the cause of the problem.
When I start via the remote, the starts up, but only runs for a few seconds. It also cranks the starter for a long time, about 10 seconds. I believe this is because it's not getting any feedback from the tach wire telling it the engine is running.
So, I need help finding the wire. the vehicle wiring description here on 12volt says it is a PURPLE / white wire behind right side of dash, I assume below glove box? There are several boxes there, and one has a PURPLE / white wire, but as I underatand it, I should be able to measure an AC voltage on this when the vehicle is running, that varies with RPM.  I get a small DC voltage on this line but no AC.
The insturment cluster itself doesn't have a tach, but I assume they would still have run the line in.
Can anyone point me in the right direction here? Where is the engine control computer, which I believe would have the tach going into it.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 06, 2007 at 11:34 AM / IP Logged
TACH SIGNAL PURPLE / white At coil on engine   AC
Have you got your passkey bypass set up correctly?
greenenvy22
Posted: January 06, 2007 at 1:50 PM / IP Logged
Currently I am testing this with the key in the ignition, so that should be providing the correct signal.
