'07 Hummer H2 remote starter?
wiretapper
Copper - Posts: 166
Posted: January 10, 2007 at 12:01 PM / IP Logged
Any info out there on this? Gotta do one in the very near future, but not until I get some solid info on the difference between the '06-'07 year.
I understand it's now pk3, and allegedly the GMSL-2 doesn't quite work as advertised on it. Anyone??
brhaugen
Copper - Posts: 275
Posted: January 10, 2007 at 12:37 PM / IP Logged
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/BLACK          (+)          AT COURTESY LIGHT UNDER DASH
     Domelight Super          GRAY/BLACK          (+)          AT COURTESY LIGHT UNDER DASH
     LF Latch          GRAY/BLACK          (-)          AT MODULE IN DRIVERS DOOR
     RF Latch          BLACK/ WHITE          (-)          AT MODULE IN PASSENGER DOOR
     LR Latch          LT.GREEN/ BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH BEHIND LIGHT SWITCH
               PURPLE PLUG PIN A2
     RR Latch          LT.BLUE/BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH BEHIND LIGHT SWITCH
               PURPLE PLUG PIN A3
     Trunk Trigger          PINK/BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH BEHIND LIGHT SWITCH
               PURPLE PLUG PIN A1
     Alarm Disarm          LIGHT GREEN          (-)          AT MODULE IN DRIVERS DOOR
     Parking Lights          GRAY/BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH BEHIND LIGHT SWITCH
               BROWN PLUG - PIN #2
     Data Bus          AT DIOGNOSTIC CONNECTOR PIN 2
     Convenience
     Headlights-Lo          WHITE          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          BROWN          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          WHITE          (-)          AT VEHICLE HAZARD SWITCH HARNESS
     Wipers-Lo          BLUE          (-)          AT VEHICLE WIPER SWITCH HARNESS
     Wipers-Hi          BLUE/WHITE          (-)          AT VEHICLE WIPER SWITCH HARNESS
     Seat Mem 1          RED          (+)          AT MODULE IN DRIVERS DOOR
     Seat Mem 2          PINK          (+)          AT MODULE IN DRIVERS DOOR
     Remote Start
     Ignition 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BROWN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSLOCK IIŽ ANTI-THEFT SYSTEM
     Anti-Theft Descript          THE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
     Key Sense          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
     Tachometer          UNCOMMON COLOR          (AC)          ANY INJECTOR NOT PINK
               PCM BLUE CONN. PIN 36, 3
     Speed Sense          GREEN / WHITE          (AC)          AT PCM MODULE NEAR BATTERY ON DRIVERS SIDE OF ENGINE
               BROWN PLUG - PIN #2
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          LIGHT GREEN          (+)          IN HARNESS AT LIGHT HOUSING
               OR BCM BLACK PLUG PIN F
     Horn          BLACK / YELLOW OR BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH BEHIND LIGHT SWITCH
               GREY PLUG PIN B9
     Modules
     WIRE          LOCATION
     Module 1          BCM-ON THE TOP LEFT SIDE OF THE I/P ABOVE THE FUSE BLOCK - I/P
     Module 2          PCM-IN THE LEFT FRONT OF THE ENGINE COMPARTMENT
     Doorlocks/Windows
     Databus Wire          PURPLE
     Power Unlock          WHITE          (-)          AT SWITCH ON RIGHT REAR ROOF PILLAR IN CARGO AREA
               *TO INTEGRATE WITH THE OEM DOOR LOCKS AT ANOTHER PLACE IN THE VEHICLE, YOU WILL NEED A MULTIPLEX ADAPTER.
     PowerLock          LIGHT BLUE          (-)          AT SWITCH ON RIGHT REAR ROOF PILLAR IN CARGO AREA
     Driver Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     Pas Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     LF Window Up          DARK BLUE          (REV)          AT MOTOR IN DOOR
     LF Window Dn          BROWN          (REV)          AT MOTOR IN DOOR
     RF Window Up          DARK BLUE          (REV)          AT MOTOR IN DOOR
     RF Window Dn          BROWN          (REV)          AT MOTOR IN DOOR
     LR Window Up          DARK BLUE          (REV)          AT MOTOR IN DOOR
     LR Window Dn          BROWN          (REV)          AT MOTOR IN DOOR
     RR Window Up          DARK BLUE          (REV)          AT MOTOR IN DOOR
     RR Window Dn          BROWN          (REV)          AT MOTOR IN DOOR
brhaugen
Copper - Posts: 275
Posted: January 10, 2007 at 12:39 PM / IP Logged
Last post from Audiovox
wiretapper
Copper - Posts: 166
Posted: January 10, 2007 at 3:28 PM / IP Logged
Thanks!
Weird though....looks exactly like '06 wiring to me, including the Passlock II info. Hmmm.......
extreme1
Silver - Posts: 1,070
Posted: January 10, 2007 at 10:24 PM / IP Logged
I did an 07 and it was same as an 06, had to hook up 2nd accesory though.
wiretapper
Copper - Posts: 166
Posted: January 11, 2007 at 10:18 AM / IP Logged
So I guess the '07 STILL has Passlock II and not PK3. Interesting. The info I got made it look like the wiring for the '07 Tahoe.
brhaugen
Copper - Posts: 275
Posted: January 11, 2007 at 12:46 PM / IP Logged
Could be that the H2s are keeping the 06 Tahoe wiring????
wiretapper
Copper - Posts: 166
Posted: January 11, 2007 at 2:46 PM / IP Logged
Well, you guys are gonna love this! Turns out it IS an '06 after all. Gotta love these people! We had all the customer's info that he gave, including the year. Now he claims he never said it was an '07. Yeah, OK. I wrote it myself as he was telling me. ...idiots.
Thank you all anyway!
