Toyota Yaris door actuators?
dexinefx
Member - Posts: 32
Posted: January 15, 2007 at 1:17 AM / IP Logged
hi have a base yaris and was trying to install power door locks over the weekend but when i opened the door panels i did not see the regular rods and stuff for the locking system all i saw was one cable that hooked up to the door lock thinky on the door...couldn't figure out how to install the actuators..has anyone out there installed actuators in a yaris before??? if so how did you do so???? thanks.
Mike M2
Platinum - Posts: 2,652
Posted: January 15, 2007 at 6:32 AM / IP Logged
We usually don't do cable drive locks so we turn away any Yaris that comes to us for locks. That doesn't mean it isn't possible. You can try removing the door latch assembly and see if it is possible to mount an actuator to it and make it work. We have done this a few times on other cars, like Nissan trucks. It's a real pain, but if it's your own car it might be worth the extra effort....
Mike M2
Tech Manager
CS Dealer Services
captainzab
Silver - Posts: 606
Posted: January 15, 2007 at 9:24 AM / IP Logged
You can go to the junkyard and see if they got the entire assembly with actuators built into it arleady.
I was never able to install regular actuators into cable type
Note: You Always Dont Get What You Pay For.
soultinter
Copper - Posts: 170
Posted: January 15, 2007 at 9:41 AM / IP Logged
Peripheral has a part out now for doing cable door locks
tbone587
Copper - Posts: 167
Posted: January 15, 2007 at 6:07 PM / IP Logged
I have done actuators in cable door lock systems a few times, but never in a yaris..  Im sure it is the same though.  It definately is a little harder to do, but you can do it.  U have to cut the sleeve of the cable system to expose the actual cable running through.  You also need to secure the cable to the door so it has more tension.     The most recent vechiles i have done with cable lock systems were hondas and ford focuses.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 15, 2007 at 8:46 PM / IP Logged
look foward to where the cable attaches to the handle (the pull). Is there any plastic you can put a hole in and run the part (the rod clamp) all the way up to the plastic. This is how yado it on a Hyundai elantra. say a 2004.
delexatek
Member - Posts: 8
Posted: January 22, 2007 at 2:28 AM / IP Logged
yes on the yaris you have to drill a hole through the plastic lever itself. you'll need to cut a notch out of the top of the piece before drilling. it's very similar to a 05-07 corolla actuator install
concepts99
Member - Posts: 24
Posted: January 27, 2007 at 9:11 PM / IP Logged
xscash
Copper - Posts: 317
Posted: February 13, 2007 at 12:32 PM / IP Logged
concepts99 wrote:
See this
http://www.autotoys.com/x/cust/product.php?productid=6278
great part......5.50$ from microalarm.com
expandable sound
south of boston
j12v
Copper - Posts: 58
Posted: February 14, 2007 at 2:38 AM / IP Logged
Ive worked at a Toyota dealership before and when the Yaris's first came in I honestly thought it was going to be a cake job... Unfortunately, I pulled a Yaris that did NOT have power door locks nor a radio. It took me about 3 hours to finally figure out how to mount the actuator though, and the most hardest part IMO is slipping the door panel back in.
I used a regular actuator and no special cable attaching things like the link posted above. I did however what delex had mentioned which was drill into the locking lever and cut a piece of plastic from the top portion right above the locking lever. Then I screwed back in the door handle, and mounted the actuator I believe to the left (If you were doing the drivers door; facing it). Now that everything was in place, I removed the door handle screw and snapped the door handle back into the door panel. Now comes the tricky part of sliding back on the door panel. Shouldnt be too hard though once you figure out where to mount the actuator
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
