Weird toyota 4 runner A/C problem
H2prix
Member - Posts: 27
Posted: January 24, 2007 at 7:34 PM / IP Logged
A few days ago we had a customer come back on us...she complained that her a/c controls just stay in the max air mode..and was not able to lower it. This happens in remote start mode, and also with the key. Just wondering if anyone had any input on this situation.
duct tape
Copper - Posts: 125
Posted: January 24, 2007 at 8:11 PM / IP Logged
did you check to make sure that all harnesses are plugged back in on the heater controls?
Mike M2
Platinum - Posts: 2,652
Posted: January 24, 2007 at 9:06 PM / IP Logged
Only one single plug on the AC controls. Did this occur right after the RS install, or down the road?
Mike M2
Tech Manager
CS Dealer Services
imseth85
Copper - Posts: 71
Posted: January 24, 2007 at 9:40 PM / IP Logged
I'm just wondering, that car does not have rear seat AC controls does it?
Seth Alvo     NY
Mobile Electronics Installer
H2prix
Member - Posts: 27
Posted: January 24, 2007 at 10:00 PM / IP Logged
This did occur after the RS yes. The only connections made were: all high current wire:12v+,ign,acc...etc..tach,brake,parking lights..no a/c controls were touched..
KarTuneMan
Platinum - Posts: 7,056
Posted: January 24, 2007 at 10:45 PM / IP Logged
What year....? You need to put that in your post.
bmwpwner
Copper - Posts: 174
Posted: January 24, 2007 at 11:58 PM / IP Logged
if it is on a newer toyota sometimes the computer gets confused like on newer dodges. check all your connections and if everything is physically connected and power up properly then try disconnecting the negative battery terminal and letting the vehicle sit for about 10 - 15 minutes. reconnect and check. i had this happen on a dodge ram a couple of weeks ago and that fixed it right up. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
mobilecustoms
Silver - Posts: 397
Posted: January 25, 2007 at 6:29 AM / IP Logged
also see if the blower motor resistor is shot. usually it will work only on high if the resistor is shot.
H2prix
Member - Posts: 27
Posted: January 25, 2007 at 8:23 PM / IP Logged
temp. monitor plug was not plugged in after putting up the dash..this plug was located right under the steering column..and must have unplugged it self..after i removed the dash, and didnt look for anything to plug back in when i put the lower dash back together..thats what happens when ya get rushed..it was busy that day..thanks tho guys
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
