07 jeep compass remote start
slicksam
Copper - Posts: 291
Posted: February 03, 2007 at 10:24 PM / IP Logged
I would like to know if anyone has done the jeep compass 2007?
need wiring info. I have install a remote starter on it and I was wondering if I should get the bypass that does transponder and doorlocks. if the doorlocks are easy to connect then i will get the bypass just for the transponder...much cheaper.
Testing is the key
lsondubz
Copper - Posts: 193
Posted: February 04, 2007 at 2:48 PM / IP Logged
I believe this is the same as an 07 Dodge Caliber, if so using a bypasskit PKU-CH2X helps alot for MUX and Sentry bypass
DIRECTWIRE™ WIRING INFORMATION - DODGE / CALIBER / 2007 / Remote Start
[PRINT THIS PAGE]
12volts RED / orange (10A)  +  ignition harness
Starter pink/lt. blue  +  ignition harness
Notes: Not all models have the starter wire. On those vehicles just use the second starter wire.
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter wire
Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory N/A
Keysense N/A
Power Lock lt. GREEN/ dk. green  -  DKP or cluster, brown plug, pin 18
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is negative trigger thru a 249 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor lt. GREEN/ tan to tan/dk. blue  5wi DKP or cluster, bk 10 pin plg, pin 9
Unlock Motor lt. GREEN/ org to tan/dk. green 5wi DKP or cluster, bk 10 pin plg, pin 5
Parking Lights+ WHITE/ purple  +  driver kick, harness to rear
Parking Lights- (LIN data bus)
Hazards (LIN data bus)
Turn Signal(L) WHITE/ red (F), dk. grn/red (R) +  lights or fuse block under hood
Turn Signal(R) WHITE/ tan (F), WHITE/ yel (R)  +  lights or fuse block under hood
Reverse Light WHITE/ lt. green  +  driver kick, harness to rear
Door Trigger see notes  -  each kick or cluster, brown plug
Notes: The LF door is PURPLE / black in pin 3. The RF door is PURPLE / white in pin 11. The LR door is PURPLE / gray in pin 5. The RR door is purple / YELLOW in pin 6. Use all four wires and diode isolate each.
Dome Supervision yellow/white  +  A pillar or cluster, brn plug, pin 4
Trunk/Hatch Pin PURPLE / lt. blue  -  DKP or cluster, brown plug, pin 13
Hood Pin PURPLE / lt. blue (export only)  -  pin switch or fuse block under hood
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT BROWN / gray or BROWN / yellow ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire dk. GREEN/ gray  +  switch or cluster, brown plug, pin 8
Parking Brake dk. GREEN / WHITE  -  switch or cluster, brown plug, pin 7
Horn Trigger dk. GREEN/ purple  -  sw or cluster, bk 20 pin plg, pin 10
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
07 jeep compass remote start -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
No
Type:
Multiplex
Part #: 456LW
Notes:
Combo Interface
Required:
No
Type:
Data Bus
Part #: IOM-Chrysler-7
Notes: When using the IOM-Chrysler-7 it is not necessary to use doc 1084. That part takes care of 2nd starter and accessory, locks, and bypass.
Smart Starter Kill Relays: Not Available
