611t
megatfauzi76
Copper - Posts: 93
Posted: February 08, 2007 at 3:01 AM / IP Logged
I confused function of 611T.... What can i do if i have this 611T? How it works? Anyone have wiring diagram for this?
Thank you
Big Dog
Gold - Posts: 1,265
Posted: February 14, 2007 at 4:00 PM / IP Logged
It's a timer module with built-in relay.
Here it is: 611
Prepare your future. It wasn't the lack of stones that killed the stone age.
jose23
Member - Posts: 24
Posted: February 14, 2007 at 4:52 PM / IP Logged
There were actually two different versions of the 611T. I say WERE because I believe that they're both now discontinued. Both were latching relays. What this means is that the relays never had any current draw other then when you triggered it. You trigger it once, the relay would 'latch' closed. You trigger it again, it would 'unlatch'. Again, in both instances the relay would not need any power to remain latched or 'unlatched'.
Regarding the two types. The one that Big Dog mentions above was the newest version that had a built in timer that gave you the option of setting an amount of time (1-100 sec.) that the relay would stay latched. The older version was simply a straight active latching relay (without the timer feature) that would stay latched until you triggered the relay again.
megatfauzi76
Copper - Posts: 93
Posted: February 14, 2007 at 7:08 PM / IP Logged
Thanks...So which are better 611T or 528T( pulse timer delay)?
