how alarm sensors work?
megatfauzi76
Copper - Posts: 93
Posted: February 08, 2007 at 3:30 AM / IP Logged
Hai..
Can i know the concepts and the theory...how alarm sensirs works? Example...Glass Break Sensors...From what I know..it have 3 wires...
1st wire - To +ve supply
2nd wire - To -ve supply
3rd wire -ve output from the sensors
Ist correct? Meanning to said...the alarm will trigger when receive -ve current rite? What the voltage of the current?
brhaugen
Copper - Posts: 275
Posted: February 08, 2007 at 6:45 AM / IP Logged
Your are correct, the signal sent on the 3rd (trigger) wire is very small in the neighborhood of 300ma depending on the mfg.
KPierson
Platinum - Posts: 3,527
Posted: February 08, 2007 at 7:52 AM / IP Logged
Most present day alarm sensors are considered 'power' sensors.  Powered sensors have built in processing of the actual sensor, so they require a constant source of power.  The onboard processor then controls the seperate (-) outputs to trigger the alarm brain.
Kevin Pierson
megatfauzi76
Copper - Posts: 93
Posted: February 08, 2007 at 6:31 PM / IP Logged
Means, the 3rd wire..I can hook to the door trigger rite? Alarm will trigger if the sensor detect something?
