2006 grand cherokee defrost
peterubers
Silver - Posts: 706
Posted: February 19, 2007 at 9:20 AM / IP Logged
I've done several defrost triggers on imports -- usually b/c it's really easy to get to the back of the defroster switch and isolate the wire that needs to trip the defroster wire .. then supplying THAT wire with a pulse of ground from the r/s brain on startup --
How difficult is it to do this on a 2006 Jeep Grand Cherokee -- is it the same concept -- there will be several wires at the back of the defrost switch, I use my DMM to determine which wire goes to ground when I press the switch .. then supply that wire ground... ?
Or is the defroster button integrated into a more advanced HVAC digital interface?  Thanks in advance
The search function is your friend.
KarTuneMan
Platinum - Posts: 7,056
Posted: February 19, 2007 at 10:56 AM / IP Logged
Dark blue wire behind the control, needs a NEG(-) latched pulse.
It won't turn on the indicator on the dash, so touch the rear glass to know you got it.
peterubers
Silver - Posts: 706
Posted: February 19, 2007 at 1:45 PM / IP Logged
Thanks -- great info as always KarTuneMan.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
