2006 mazda rx 8, clifford 10.2x
05gt
Silver - Posts: 628
Posted: February 20, 2007 at 1:11 PM / IP Logged
quick question
I am installing the clifford 10.2x in this vehicle and I have a question
the door lock harness that comes with this kit has 7 wires a BLACK/ white, WHITE/ black, GREEN/ black, PURPLE / black, BROWN / black, blue/black and a purple,  now this vehicle has a 1 wire system and needs a ground and a  resistor to lock and ground to unlock
just wondering how to wire this up
thanks mike
Hymer
Silver - Posts: 695
Posted: February 20, 2007 at 1:22 PM / IP Logged
Not sure what the wire colors are or what they corespond to, but its a relay of some sort.. you will end up not useing the 2 wires that corespond with 87A of he relay, ground the wires of pin 30 of the relay and the other 2 will be lock and unlock from pin 87 of the relay, tie whattever one needs to go to ground drectly to the lock/unlock of thecar, then the other you will run your resistor through, and connectit to the cars lock unl;ock...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
KarTuneMan
Platinum - Posts: 7,056
Posted: February 20, 2007 at 1:28 PM / IP Logged
Built in relays with maybe a drivers door priority trigger?
The wires (in the manual) should give descriptions. N.O.,N.C., and common. Right?
05gt
Silver - Posts: 628
Posted: February 20, 2007 at 1:33 PM / IP Logged
yah they have descriptions
purple unlock 87 normally open (input),   blue/black unlock 30 common (output),   BROWN / black unlock 87A normally closed
violet/black lock 87 normally open (input),   GREEN/ black lock 30 common (open),   WHITE/ black lock 87A normally closed and then BLACK/ white is a domelight supervision wire relay input 87 which I don't need
Hymer
Silver - Posts: 695
Posted: February 20, 2007 at 1:48 PM / IP Logged
Ground blue and black / green and black, dont use brown black / white black, Purple to the one wire locking and voilet and black to the same wire.. just remember to put the resistor to the right wire off the alarm...
05gt
Silver - Posts: 628
Posted: February 20, 2007 at 2:08 PM / IP Logged
the violet/black and the violet wire connect with a fuse and then comes out of the fuse as one wire which is violet/black, this I believe will go to ground
wouldn't I hook the blue/black up to the lock/unlock wire in the car and the GREEN/ black wire with a 1k ohm resistor also to that same wire
correct me if I am wrong
Hymer
Silver - Posts: 695
Posted: February 20, 2007 at 2:36 PM / IP Logged
Yep, if the wires have a fuse to them, then run those to the ground, and the othere two to the locl/unlock wire.. It really doesnt matter much scince it is a (-) setup but good genral practice would say put the fuse to the feed side of the circuit...   Good Luck!
05gt
Silver - Posts: 628
Posted: February 20, 2007 at 2:38 PM / IP Logged
thanks for the info
Hymer
Silver - Posts: 695
Posted: February 20, 2007 at 2:42 PM / IP Logged
Any time....
Posted: February 20, 2007 at 5:04 PM / IP Logged
Take purple and PURPLE / black to ground, place resister in GREEN/ black, then join to blue/black thence to multiplex (single lock-unlock) cable. Don't use WHITE/ black, brown black. What's a 10.2x? Haven't seen new stuff  over hear yet; ha ve you got Wizard to USB yet?
