2005 smart car wiring info?
lauf
Posted: February 21, 2007 at 7:51 AM / IP Logged
I have a 2005 Smart car, and am doing an alarm/starter in this vehicle.    The only issue i am having, is that i have to find the disarm wire, and so far having no luck finding any information on this vehicle for wiring schematics? any help would be great!
thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: February 21, 2007 at 9:58 AM / IP Logged
There is no information on DEI's site that lists any 2005 SmartCar. They list a couple other years and models, but none listed have a factory arm/disarm listed. If you are sure that the vehicle has an alarm, take off the driver's door panel and look at the key cylinder. The key cylinder would have a wire attached to it that goes to ground when unlocking with a key. See if you can trace that wire back into the car or tap into it right in the door.
