lexus sc430 remote top?
skandalous
Member - Posts: 15
Posted: March 05, 2007 at 8:42 PM / IP Logged
I am looking to add a remote top opener to my Lexus SC430. What will I need to do this? Thanks in advance
profuse007
Gold - Posts: 2,015
Posted: March 05, 2007 at 9:40 PM / IP Logged
you will need a unit w/ two auxillary channel ouputs to trigger open and close.
use viper 650xv, or python 460hp. just two possibilities w/ very small remote, size of a quarter.
Sun Roof open/close      yellow/black - GREEN/ YELLOW       -       left plug of A/C display unit
lexus sc430 remote top? -- posted image.
Houston,TX
skandalous
Member - Posts: 15
Posted: March 05, 2007 at 10:29 PM / IP Logged
Is that an actual pic of an SC430 convertible wiring harness? With the two solutions you metioned can I also add remote start?
profuse007
Gold - Posts: 2,015
Posted: March 06, 2007 at 9:09 AM / IP Logged
yes, there is endless of cool things you can do to that model lexus. If youre goin to spend some money, get Viper 7900. It's a color screen LCD w/ Li-Ion rechargable battery, the coolest feature so far I've seen marketed.
If you're driving this kind of vehicle, I wouldn't mind shelling out some money to get the best product.
Houston,TX
skandalous
Member - Posts: 15
Posted: March 06, 2007 at 9:49 AM / IP Logged
Thanks for the advice. Can I add remote start and remote top and still keep the factory alarm? How about wiring diagrams for the installation?
profuse007
Gold - Posts: 2,015
Posted: March 07, 2007 at 5:26 PM / IP Logged
Yes, fact alarm still retain.
have you resolved your key situation?
Houston,TX
skandalous
Member - Posts: 15
Posted: March 07, 2007 at 9:34 PM / IP Logged
I did get a the key issue resolved.. A week and $1500 later...lexus sc430 remote top? -- posted image.  Sorr for the noob questions but If I integrate both remote start and top to the factory alarm can I use the OEM key to perform remote start and top operations?  Will I need relays for the install?
skandalous
Member - Posts: 15
Posted: March 07, 2007 at 10:10 PM / IP Logged
For example a dei 561T for remote start and a dei 530T for remote top integrated into the factory alarm?
profuse007
Gold - Posts: 2,015
Posted: March 08, 2007 at 9:11 AM / IP Logged
I recommend getting a stand-alone unit. Search the forum under remote start add-on and there are numerous answer telling you why.
The bottom line, dont use 561T and 530T.
If you're installing this yourself, get started on how to install basic alarm. No offense, you might run into crap-hole if you do this all at once.
Houston,TX
skandalous
Member - Posts: 15
Posted: March 09, 2007 at 12:10 AM / IP Logged
How about if just decide to add remote top to my OEM alarm? Is it possible to just connect a window roll down module to the my factory alarm setup?
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
