Door Triggers
channer
Posted: February 06, 2003 at 11:13 AM / IP Logged
I am hooking up an Avital 3300 to my 95 4Runner.
The alarm has both + and - door trigger inputs.
Do I need both, or is this just a bonus feature of the alarm?
Also, for the door lock outputs, the wiring diagram says the wires are blue/white and blue / YELLOW, but there are two blue/white wires on the door control relay.
I could test them, but I would like to avoid it since I have everything unhooked.
Chris Channer
JWorm
Platinum - Posts: 2,208
Posted: February 06, 2003 at 8:05 PM / IP Logged
You only need the negative door trigger for that vehicle.
Just guess on the lock wires....if your wrong you'll probably just blow something like a fuse....ECM....BCM.
Do it right and break out the multimeter.
Bnluis
Silver - Posts: 578
Posted: February 06, 2003 at 8:20 PM / IP Logged
 Catch your wires  coming out of the door boot  and test them   with a multimeter. is better than trying to guess.  Good Luck.
Luis
Sound Waves
channer
Posted: February 06, 2003 at 9:48 PM / IP Logged
Thanks for the info.
I just wanted to see if anyone knew without having to break out the DMM.
Thanks anyway
Chris Channer
Chris Luongo
Platinum - Posts: 3,746
Posted: February 07, 2003 at 6:23 PM / IP Logged
"I just wanted to see if anyone knew without having to break out the DMM."
How did you get the rest of the install done?  Just by guessing?
If the door lock wires don't test by operating the switch on the door, try turning the key in the door cylinder instead---many Toyotas are wired this way, but I'm not sure about the '95 4Runner.
Also, the harness that has the door trigger will be running upward from the fuse box, toward the car's A-pillar-----it'll have two wires if you don't have a sunroof; four wires if you do.
channer
Posted: February 07, 2003 at 7:22 PM / IP Logged
I did most of the install with the information from the Vehicle Information Database, since the wire colors were exact in most cases. It is probably not the safest way, but it was raining outside, and I had no shelter, so I disconnected the battery to be careful. I did end up testing the wires, and the two smaller ~18 gauge wires in the center of the harness were the right ones.
Everything else works except the door trigger input, I'll have to go back and re-test.
Thanks to all for the help
Chris Channer
