2007 chevy aveo, tach wire
ajzautoextreme
Member - Posts: 10
Posted: March 18, 2007 at 5:34 PM / IP Logged
on the 07 aveo hatchback manual tranny  which wire would the tach wire be at the instument panel, some of the wire schematic sites say pin 3 but the funny thing is there not numbered so i checked all 3rd pins from outside in and came up with 12 to 14 volts with vehicle running any advice would be greatly appreciated, trying not to run to the ecm on the shock tower.  thanks in advance
KarTuneMan
Platinum - Posts: 7,056
Posted: March 19, 2007 at 1:36 PM / IP Logged
 TACH SIGNAL YELLOW/BLACK (10-pin con.) White At coil on driver's side of engine  AC
ajzautoextreme
Member - Posts: 10
Posted: March 19, 2007 at 8:29 PM / IP Logged
thanks i will look at it  and i thank you for the reply
