aps 996 programming
kennilope
Member - Posts: 7
Posted: March 24, 2007 at 11:02 AM / IP Logged
Hi there..
I have a Prestige APS 996 with remotre starter.. Alarm work great...but I want to program it to do the following
Auto lock the car when key take off and close door
Auto Arming the alarm when take off key and close all door....
I am having problem programing it.. can't get into the mode I want to....
If anybody know how to please let me know
thank you
Twelvoltz
Platinum - Posts: 2,384
Posted: March 24, 2007 at 1:53 PM / IP Logged
Follow the instructions in the installation manual very carefully, if you are off one step the programming will not take. If you do not have your installation manual you can head over to techservices.audiovox.com, sign up for a free account and download your manual.
kennilope
Member - Posts: 7
Posted: March 24, 2007 at 3:19 PM / IP Logged
i have the manual and i follow this step
Turn ignition on..
press valet switch 3x
turn ingnition off.. and one .. hear one short beep and one long
then when i press the valet button again .. it give me 2 beeps..
i tried to go to option 5 and 6 on the first mode but it wont....
any clue???
I had it work last week.. now i messed it up.....
d-rail
Posted: March 25, 2007 at 12:02 AM / IP Logged
Once you get into the programing mode you have to watch the LED blinks for each function. Everytime you hit the valet button the LED shoud blink the number of times that corresponds to the function number you are trying to change, the chirps you hear are where that function is currently set at and then you hit the lock or unlock button to change that function. Audivox/prestige is a challenging system to set up. Good Luckaps 996 programming -- posted image.
hernandezj
Posted: March 25, 2007 at 12:27 AM / IP Logged
in your notebook for your unit you should see how to program default operations try that typically it comes programed to work from the very first installation
ECLIPSEAUTOhanfofd
kennilope
Member - Posts: 7
Posted: March 25, 2007 at 1:46 AM / IP Logged
thank you guys I will try it out monday or tuesday...
kennilope
Member - Posts: 7
Posted: March 26, 2007 at 3:03 PM / IP Logged
can anybody tell me how to go to mode 1.
it keep going to mode 2 when i go through menu...
d-rail
Posted: March 26, 2007 at 5:34 PM / IP Logged
Key on, valet button 3x's, one chirp, key off followed by one long churp (I believe) then imediately turn key back, this is program mode 1 from there you use the valet to take you through the different functions but again watch the LED for the numbered position you are trying to get to. don't listen to the chirps they only tell you what feature you are turning on or off or advancing to in that feature.
kennilope
Member - Posts: 7
Posted: March 28, 2007 at 7:24 AM / IP Logged
Thank you guys...
Finished programming it..
Now it works what I want it to do.... save me $$$$$$$$$$$$$$$$$$ too..
so happy :-) Coffee is in the house.
