791vx, 93 honda del sol
nbboy7
Member - Posts: 19
Posted: March 24, 2007 at 2:04 PM / IP Logged
Ok here goes I installed my viper 791 alarm today everything works but the shock sensor. I check all the conection and its fine. I don't know what it can be i did the troubleshoot to turn the key on and off but it still didn't work. I also have a question when I remote start the car the lights stay flashing is there a way to turn that off or is it not reading mt Tach. If it help I installed it on my 93 Honda del sol Si If any one can help I'll galdly apprecate it. Thank you
Twelvoltz
Platinum - Posts: 2,384
Posted: March 24, 2007 at 2:14 PM / IP Logged
Flashing lights: This is how DEI systems come from the factory, set to flashing parking lights while remote started. This is a programmable option listed in your installation manual.
Shock Sensor: Does the LED on the impact sensor light up at all? The sensor will light up even when the alarm is disarmed any time it senses an impact. If it is not lighting up at all, I would make sure both ends of your harness are plugged in tightly. If it lights up but not without a really strong impact, then adjust the sensitivity of it by turning the adjustment screw.
nbboy7
Member - Posts: 19
Posted: March 24, 2007 at 2:40 PM / IP Logged
For the flashing lights I do not know how to program the vallet parking mode.  The  manual was not very clear.  If you can kind of break it down.  Now for the shock sensor it does not light up at all.
nbboy7
Member - Posts: 19
Posted: March 24, 2007 at 4:04 PM / IP Logged
Thank you very much you helped with the info u were able to give me and I got it to work.
