2006 ford expedition ed bau 2wd alarm
bluescreen
Posted: March 25, 2007 at 12:31 PM / IP Logged
Need remote start / alarm wiring schematic for 2006 Ford Expedition, 5.4L, Ed Bauer, 2WD.
Thank you
alex79
Member - Posts: 16
Posted: March 25, 2007 at 12:46 PM / IP Logged
WIRING INFORMATION: 2006 Ford Expedition
WIRE WIRE COLOR LOCATION
12V CONSTANT WIRE LT.GREEN/ PURPLE Ignition harness
12V IGNITION WIRE BLUE/LT.GREEN Ignition harness
12V ACCESSORY WIRE BLACK/ LT.GREEN Ignition harness
STARTER WIRE RED / LT.BLUE Ignition harness
PARKING LIGHTS (+) BROWN Headlight switch
POWER DOOR LOCK (-) PINK / YELLOW
POWER DOOR UNLOCK (-) PINK/GREEN
Large Harness In Driver’s Kick Or Gray Plug
At Vehicle Security Module
Vehicle Security Module is a black module in the passenger kick panel mounted on the side close to the firewall. It has three plugs facing
towards the back of the vehicle.
DOOR TRIGGER (+) BLACK/ LT.BLUE
LIFTGATE GLASS RELEASE (+) WHITE/ PINK Blue Plug At Vehicle Security Module
BRAKE WIRE (+) GREEN Brake Switch Or Large Harness In Driver’s
Kick Panel Running To Rear Of Vehicle
TACHOMETER WIRE Any wire NOT RED / LT,GREEN At Any Ignition Coil
HORN TRIGGER (-) DARK BLUE Green Plug At Vehicle Security Module
LEFT FRONT WINDOW UP WHITE/ BLACK At Window Switch In Driver’s Door
LEFT FRONT WINDOW DOWN TAN/LT.BLUE At Window Switch In Driver’s Door
RIGHT FRONT WINDOW UP TAN/LT.BLUE
RIGHT FRONT WINDOW DOWN WHITE/ YELLOW
LEFT REAR WINDOW UP YELLOW/LT.BLUE
LEFT REAR WINDOW DOWN GRAY/ORANGE
RIGHT REAR WINDOW UP RED / BLACK
RIGHT REAR WINDOW DOWN YELLOW/BLACK
At Harness In Driver’ Kick Panel From
Driver’s Door
Most models are equipped with the Securilock anti-theft system. This must be bypassed when installing a remote start.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
