mitsubishi galant 2003 distributor
adavila
Member - Posts: 12
Posted: April 01, 2007 at 9:44 PM / IP Logged
where is the distributor located with the white wire that i need.. for the remote start...?? please give many details.. thanks...
docsautomotive
Copper - Posts: 66
Posted: April 01, 2007 at 9:58 PM / IP Logged
what year is it and what size motor automatic or standerd usa or canada or california need to know all this
never stop
adavila
Member - Posts: 12
Posted: April 01, 2007 at 10:02 PM / IP Logged
oh oh.. im sorry.. 2003 galant.. v6 3.0 iter.. automatic transmission.usa.. all the way.. thankss..
peterubers
Silver - Posts: 706
Posted: April 02, 2007 at 4:13 PM / IP Logged
TACH BLACK/ BLUE or WHITE/ GREEN  @ IGNITION COIL
I'm assuming that you need this wire for the tach ... use the ignition coil wire and route your wire/looming away from "hot" (as in temperature, not current) engine parts.  There are six ignition coils .. pick your coil .. you'll find three on one side of the engine, and three on the other.  You may have to remove a plastic fascia cover to see these ignition coils (they are black .. three in a row on one side, three in a row on the other side).  Often they'll use torque or hexagonal bolts to keep this plastic fascia tacked down to the engine .. have the proper tools handy.
The search function is your friend.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
