98 Maxima Remote Start
adamsc50
Posted: February 08, 2003 at 7:09 PM / IP Logged
I'm haveing trouble getting remote start to work on my Maxima.  I can get it to turn over but it won't stay running.
Please help me!!!
Bnluis
Silver - Posts: 578
Posted: February 08, 2003 at 7:55 PM / IP Logged
      You said you can get it  to turnover, but it  won't stay running. Make sure you connect  your second starter  wire.
STARTER|                                    blk/yel - blk/wht *6|+  |ignition harness            |
SECOND STARTER|grn/blk - RED / blu *6|+  |ignition harness
*6 The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
  Also make sure, to have a good  tach  wire, if you are using one.
  TACHOMETER|WHITE/ green         |   |ECM *5
 *5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
adamsc50
Posted: February 09, 2003 at 9:08 AM / IP Logged
Thanks Luis
I'm going to try that after lunch.  That 2nd wire you said to connect is the only other wire that i'm not engaging with the remote start.  And that's why it's not hot when i turn the car on, becuase it's only hot during crank.
Bnluis
Silver - Posts: 578
Posted: February 09, 2003 at 10:43 AM / IP Logged
 Try using a relay,  when connecting the second starter  wire.
Luis
Sound Waves
adamsc50
Posted: February 09, 2003 at 7:35 PM / IP Logged
It worked!
the relay idea was a good idea and it worked the first time.
Thanks again
Bnluis
Silver - Posts: 578
Posted: February 09, 2003 at 8:24 PM / IP Logged
No problem , anytime
Luis
Sound Waves
